Cisco 1941 with IP Base License
I currently purchased, Cisco 1941/K9 with 2 onboard GE, 2 EHWIC slots, 1 ISM slot, 256MB CF default, 512MB DRAM default, IP Base.
Questions
1. With IP Base License, will I be able to run Frame Relay? I really need reference on what works and what doesn't between these different technology package licenses ? Actually frame relay is running on it right now, hope it doesn't suddenly stop after 60 days...
2. As I understand in order to run MPLS, I will need to upgrade to Data License "SL-19-DATA-K9".
   Since, I already have a Cisco 1941 to upgrade it, I need to order a spare license / paper PAK?
3. Does the IP Base License support site to site IPSEC VPN or do I need to purchase a security license "SL-19-SEC-K9"
4. Can I have both security and data license activated on the same device ?
5. If I do activate security or data license will I be able to use the IP Base features at the same time?
6. If I purchase a new Cisco 1941 with Data or Security License do I need to purchase the IP Base License then upgrade the license?
7. Is the 1941 suited for voice application routing ?
Sorry for the lot of questions.. but the more I read the more confusing it becomes.
Hope some one can clarrify the items above.
Thanks.
Giuseppe Larosa
Hello Paul,
the reference document is the following for licensing on ISR G2
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html#wp9000768
1) FR should be supported in IPBase license
from above document
>>Offers features found in IPBase IOS image on ISR  1800,2800 and 3800 + Flexible Netflow + IPV6 parity for IPV4 features  present in IPBase.
note X.25 is mentioned in the first table FR it isn't.
2) You need to purchase a PAK and you should be able to generate the DATA license SAL from the portal following the instructions (there are also other methods described in the document)
3)  you need SEC for IPSec VPN it means another PAK to buy
4) yes you can install all of the additional licenses in a single device
5) yes, they build on IP Base so you add features without removing any
6) no, the new device will be already with the correct licences from factory
>> On each shipped device IPBase software activation  key is installed by default. Additional keys are installed by  manufacturing depending on the customer order.
7) yes with the UC PAK
Hope to help
Giuseppe
Giuseppe Larosa
Hello Paul,
from above document
Hope to help
Giuseppe
Thanks...
So If I ordered for Cisco 1941 would the item look like this
SKU:           Cisco 1941/K9
Description: Cisco 1941 with 2 onboard GE, 2 EHWIC slots, 1 ISM slot, 256MB CF default, 512MB DRAM default, IP Base
Plus (Both or either)
     A. SL-19-DATA-K9      Data License for Cisco 1941 (Works with universalk9 image )
     B. SL-19-SEC-K9        Security License for Cisco 1941(Works with universalk9 image)
For UC ---> As I understand its not supported on 1941 ?
Thank you very much for your response..
If you are buying a new 1941 and want a Sec licence it would probably work out cheaper for you to buy the hardware with this license preinstalled (SKU: CISCO1941-SEC/K9) rather than bolting the sec license on to an IP Base model. I don't believe this option is available for the data license.
Hello Paul,
you are right no UC license is available for the C1941 I should have checked this before posting
see
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/data_sheet_c78_556319.html
>> only available licenses are:
• IP Base: This technology package is available as default.
• Data
• Security (SEC) or Security with No Payload Encryption (SEC-NPE)
Hope to help
Giuseppe
