Cisco 2500
Cisco 2500
Unit 0, memory error, csr0=0x88c3
Message was edited by: Barbara Chamberlain
When is the error generating?  i.e. during boot, after post, during normal operation, randomly
Does the error lock the system up, cause performance issues, or does the device automatically restart?
while i dont agree with the last comment made it doesn't mean that you can't replace it.  You don't have to upgrade with a more up to date product, but you probabally can replace the 2500 for 10-30USD.
rwagner
Do you get any other messages with the error?
It could be hardware failure or just be that the memory isn't big enough to load something, like the config.
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00801545eb.shtml
Also double check to make sure the flash is securely in place as a loose/damaged flash card can also spit this out for you.
No other errors, devices is used as a terminal server FEP
Replace with current product.
