Cisco 2600 - Not passing internet traffic on LAN side
eekmiester
Hello everyone,
I want to say thank you in advance for any help that I receive.
Lets start out by saying that I haven't configured anything Cisco in about 6 years, so I am rusty.
I dug out an old 2600 Router as a refresher, and something to play around with, I may use
it in my office, just for the heck of it, but probably not.
So here is my issue. I have setup a basic configuration with DHCP, and a static WAN port.
The router itself, can ping the internet (8.8.8.8) with zero issue. The router can also ping
internal devices on the LAN side, no issue. But, the LAN devices cannot get on the internet and I cannot figure out why... they cannot even ping the gateway. The router itself, is fine. Which leads me to believe it is a PAT/NAT issue. The config I have, to me, should be working, and I would appreciate a fresh set of eyes.  I have omitted some segments of the IP as it is a working address, when this router isn't in use.
Hopefully, someone can see something I am not.
Thanks again everyone,
Here is the configuration as-is:
Current configuration : 1713 bytes
version 12.4
hostname WANETROUTER
boot-start-marker
boot-end-marker
enable secret 5 $1$2f7M$33U1px0E5ttjJtkLakofc/
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.75.1
ip dhcp excluded-address 192.168.75.2
ip dhcp excluded-address 192.168.75.3
ip dhcp excluded-address 192.168.75.4
ip dhcp excluded-address 192.168.75.5
ip dhcp excluded-address 192.168.75.250
ip dhcp excluded-address 192.168.75.251
ip dhcp excluded-address 192.168.75.252
ip dhcp excluded-address 192.168.75.253
ip dhcp excluded-address 192.168.75.254
ip dhcp pool wanet
network 192.168.75.0 255.255.255.0
default-router 192.168.75.254
dns-server 65.110.96.131 8.8.8.8
domain-name wanetworking.biz
ip name-server 65.110.96.131
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
ip address 65.x.x.x 255.255.255.248
ip nat outside
ip nat enable
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.75.254 255.255.255.0
ip nat inside
ip nat enable
duplex auto
speed auto
ip default-gateway 65.x.x.x    (Double checked it is correct)
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 65.x.x.x  (Double checked it is correct to the gateway)
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet0/1 overload
access-list 100 permit ip 192.168.75.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
I have made a few changes to your config. Make sure the parts in bold match yours:
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool wanet
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.75.0
control-plane
line con 0
line aux 0
line vty 0 4
login
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool wanet
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
Hi Georg, thanks for the reply!
So just to verify you want me to remove
-ip nat enable from both interfaces
-ip default-gateway
Change the ACL to what you listed
As well as the ip inside source list1 fastethernet 0/0 overload
Don't I want the inside interface on overload fa0/1?  Or am I mistaken about that?
exactly. Give that a try, it should work...
You sir, are my hero for today!
I had to add 0.0.0.255 to the ACL but, it fired right up!
It was bothering me terribly.
Thank you so much!
