05-05-2011 02:52 PM - edited 03-04-2019 12:17 PM
I have two cisco router I am trying to setup for some testing but I am having trouble locating a part number for a cable to connect the WIC 2T dual port card on the back of one router to the WIC 2T dual port card on the back of the other router. I find cables that go to or from these cards to everyu single other port but to another WIC 2T card. WTH? lol
Can anyone tell me the reason or the point me in the right direction to find this cable? Seems impossible i even searched to the connector type and tried to find end to end of that connector. im at a loss.
Im about to buy an old serial card to put in one of them so I can have a cable that works. Thanks!
05-05-2011 08:02 PM
each of those cables has a male and female type. You will need any of those two cables for this connection, one male and one female, and just connect them together.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b0858.shtml#cables
05-06-2011 06:35 AM
So you are telling me I can get a cable with two of any of these connector types and it will plug my WIC 2T card to my other WIC 2T card?
I am looking to order one of these cables online. I understand your answer but it didn't really help my search or select a cable to order. So I guess I will randomly pick one of the connectors below and hope both ends plug into the Mini serial port on router1 and mini serial port on router2.
Thanks anyways.
V.35 DTE CAB-SS-V35MT(=) 10 feet / 3 meters Male V.35 DCE CAB-SS-V35FC(=) 10 feet / 3 meters Female RS-232 DTE CAB-SS-232MT(=) 10 feet / 3 meters Male RS-232 DCE CAB-SS-232FC(=) 10 feet / 3 meters Female RS-449 DTE CAB-SS-449MT(=) 10 feet / 3 meters Male RS-449 DCE CAB SS-449FC(=) 10 feet / 3 meters Female X.21 DTE CAB-SS-X21MT(=) 10 feet / 3 meters Male X.21 DCE CAB-SS-X21FC(=) 10 feet / 3 meters Female EIA-530 DTE CAB-SS-530MT(=) 10 feet / 3 meters Male EIA-530A DTE CAB-SS-530AMT(=) 10 feet / 3 meters Male
05-06-2011 06:39 AM
Randomly, hoping, and networking are concepts that do not go well along.
If you look in the popular auction site, you will find already made cables for back-to-back connections. Cisco doesn't make these.
05-06-2011 07:19 AM
i used v.35's in the past
as Paolo said, search for "cisco smart serial to serial cable wic-2t"
