01-27-2012 01:49 PM - edited 03-04-2019 03:03 PM
I have a 2621 with a WIC-1ADSL that connects to my ISP. Since the 2621 has 2 ethernet ports, I wanted to setup a network on the second ethernet port for testing things such as VPN into my network via my ASA5505. I have a DHCP pool set on the particular network but cannot get a client to get an address from the router. I think I might have an ACL that is blocking or need an ACL to allow bootp on the interface. Here is the config:
Building configuration...
Current configuration : 4144 bytes
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname r01
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging buffered 4096 debugging
logging console critical
enable secret 5 SECRET
enable password 7 password
clock timezone Central -6
aaa new-model
aaa authentication login default local
aaa authentication login local_auth local
aaa authorization commands 15 default local
aaa session-id common
ip subnet-zero
no ip source-route
no ip gratuitous-arps
ip options drop
ip cef
ip cef accounting per-prefix non-recursive prefix-length
ip dhcp excluded-address 10.1.100.1 10.1.100.3
ip dhcp pool DHCP_POOL
network 10.1.100.0 255.255.255.0
default-router 10.1.100.1
dns-server 4.2.2.1 4.2.2.2
ip audit po max-events 100
vpdn enable
username XXXXX password 7 password
ip tcp selective-ack
ip tcp mss 536
ip tcp window-size 5360
ip ssh time-out 60
ip ssh authentication-retries 2
interface Loopback0
ip address 10.10.10.1 255.255.255.0
interface ATM0/0 [connected to phone line]
description Physical DSL Interface
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
atm ilmi-keepalive
dsl operating-mode auto
pvc 0/XX
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0/0 [connected to outside interface of ASA5505]
description Frontier Communication Static IP
ip address aa.bb.cc.dd 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache same-interface
ip route-cache flow
ip tcp adjust-mss 1452
duplex auto
speed auto
hold-queue 100 out
interface FastEthernet0/1
description Intermediate DMZ
ip address 10.1.101.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no cdp enable
hold-queue 100 out
interface Dialer1
ip address negotiated
ip access-group autosec_firewall_acl in
ip verify unicast source reachable-via rx allow-default 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username username password 7 password
ip nat inside source list 101 interface Dialer1 overload
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
logging trap debugging
logging facility local2
access-list 101 permit udp any any eq bootpc
dialer-list 1 protocol ip permit
end
When I try to get an ip address from a client, I never receive one. But when I issue dhcp server statistics, I can see packets hitting the interface:
r01#sh ip dhcp server statistics
Memory usage 14050
Address pools 1
Database agents 0
Automatic bindings 0
Manual bindings 0
Expired bindings 0
Malformed messages 0
Secure arp entries 0
Message Received
BOOTREQUEST 0
DHCPDISCOVER 68
DHCPREQUEST 5
DHCPDECLINE 0
DHCPRELEASE 0
DHCPINFORM 0
Message Sent
BOOTREPLY 0
DHCPOFFER 0
DHCPACK 0
DHCPNAK 5
Any help? Am I blocking this with an ACL?
01-27-2012 07:51 PM
Can you try defining second dhcp pool for ASA subnet
01-29-2012 08:12 AM
Sorry, just wanted to specify that I have everthing on the inside of the ASA setup. The configuration would look like:
Internet
2621 --- Test network (10.1.100.x)
ASA
Internal Network
All I want the 2621 to do is hand out dhcp to the 10.1.100.x network. Its address is 10.1.100.1, there is a WAP200 at 10.1.100.3 and a PC for testing on 10.1.100.2. The WAP200 does not do dhcp so I am reliant on the 2621 and thus the exclusion command for the ip pool for my devices.
I removed ACL 101 and the nat statement and issued the ACL 2 commands as you stated. It still does not work. I have removed the ACL 2 now also and see if it works without anything, just free and open and it still does not work.
I can only telnet or ssh into the 2621 so not sure if the debug commands will show me anything.
I did get it to work now. Overlooked the fact that my dhcp pool was network 10.1.100.0 and it needed to be 10.1.101.0. Then the router started handing out ip's but not routing/nat to the internet or internal networks. I added:
access-list 100 permit ip 10.1.101.0 0.0.0.255 any
ip nat inside source list 100 interface dialer1 overload
interface fa0/1
ip nat inside
interface dialer1
ip nat outside
Works now. Thanks.
01-28-2012 02:05 AM
This will only nat DHCP replies and nothing else but you don't have an inside DHCP server allocating addresses to the outside world so if you want clients to go on the internet you should change this ACL 101 and just put a standard ACL:
access-list 2 permit 10.1.101.0 0.0.0.255
access-list 2 permit aa.bb.cc.xx 0.0.0.3
Now concerning the DHCP addresses problem, your clients are on the inside interface of the ASA ?
So can you provide the ASA config as well as the output fromthese 2 on the router:
-debug ip dhcp server events
-debug ip dhcp server packets
Regards.
Alain
