Cisco 2651XM - LAN traffic going through router?...
eekmiester
Hello everyone,
I would again like to thank anyone in advance that maybe able to help me.
Here is my situation, I got a router configured with help from the community, but I am experiencing a very odd issue. I have never had this happen before.
Here is my network. I have an 8 port Gigabit switch, with a Server, a desktop, and a Picostation.
Normally when I transfer files from my server, I transfer at 100MBps, the full Gigabit connection.
Prior to using this router, I had no trouble doing this. I never have had trouble transferring Gigabit speed on any network I have done with a 10/100 router as the dhcp server.
 But, when using this router I can only transfer files at 10MBps. So it is like the network is transferring at 10/100 not 100/1000. Unplug it from the switch. Bam gigabit speed between desktop and server. Plug 2600 in, bam 10/100. Both devices show 1 Gbps on the Nic Stats.. I just don't understand what I did wrong in the config. But, all the traffic must be going through the router itself then back to the switch then to the clients, therefore making it 10/100 as the 2651XM is two 10/100 ports.
Any thoughts on this?   Thanks so much!
I have included my router config, but omitted the working IPs.
Erik :)
Config - As Is:
Current configuration : 2034 bytes
version 12.4
hostname WANETROUTER
boot-start-marker
boot-end-marker
enable secret 5 $1$2f7M$33U1px0E5ttjJtkLakofc/
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.75.1
ip dhcp excluded-address 192.168.75.2
ip dhcp excluded-address 192.168.75.3
ip dhcp excluded-address 192.168.75.4
ip dhcp excluded-address 192.168.75.250
ip dhcp excluded-address 192.168.75.251
ip dhcp excluded-address 192.168.75.252
ip dhcp excluded-address 192.168.75.253
ip dhcp excluded-address 192.168.75.254
ip dhcp pool wanet
   network 192.168.75.0 255.255.255.0
   default-router 192.168.75.254
   dns-server 65.110.96.131 8.8.8.8
   domain-name wanetworking.biz
   lease 0 12
ip dhcp pool wanet2
   host 192.168.75.5 255.255.255.0
   client-identifier 0100.1517.ce1b.4c
ip name-server 65.110.96.131
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
 ip address 65.x.x.x 255.255.255.248
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.75.254 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 65.x.x.x
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 deny   10.0.0.0
access-list 1 permit 192.168.75.0
access-list 1 deny   127.0.0.0
access-list 1 deny   169.0.0.0
access-list 1 deny   192.0.0.0
access-list 1 permit 192.168.75.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input none
line vty 5 15
 login
end
6 Replies 6
johnlloyd_13
Level 9
Level 9
hi,
this router is very old and won't be able to support gig speed.
are you transferring files 'locally' or over the internet?
try to hardcode interface speed/duplex on both the router and the 8-port switch (if not a dumb switch) and see if it helps.
netcoms
Are both the server and the desktop on the same vlan (subnet)? if they are, traffic shouldn't make it to the router in the first place (the switch will be the one handling the traffic instead). check the configs on the switch ports that the desktop and the server are connected to and let us know how they are configured.
Howdy,
They are both on the same subnet and there is no vlan configured. The traffic is local. The switch isnt Cisco, it is an unmanaged TPLink switch. All the router is doing is providing DHCP,  and internet to the LAN. When I unplug the router fron the network and static both machines I get full gigabit. When the router is plugged in, and providing DHCP, the speed on the LAN is equivalent to 10/100. The NICs obviously still show Gbit uplinks to the switch. It really does not make sense.
hi,
local traffic won't hit the router and DHCP only assigns IP and should having nothing to do with the speed on your machines.
does the TP link switch supports gig ports? are you able to hardcode the machines' NIC speed/duplex settings and make sure you're using cat6 UTP cable (try also to swap cables)?
Howdy,
Yes, the switch is gigabit. I have this router setup as a test/play router. When I use my normal router, a Ubiquiti Air Router, the traffic is normal. It is also only a 10/100 router. I know local traffic does not go through the router, which is why this doesnt make any sense really. I just thought maybe I put a bad line of code in the config. The cables are good.
just an idea, but you might as well give it a try: configure the router for bridging, that way, the interface (FastEthernet0/1) that is connected to the TP Link is a layer 2 interface, not sure if that makes a difference. Below is the config (important parts marked in bold):
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool wanet
lease 0 12
ip dhcp pool wanet2
bridge irb
ip nat outside
duplex auto
speed auto
no ip address
bridge-group 1
duplex auto
speed auto
interface BVI 1
ip nat inside
no ip http server
bridge 1 protocol ieee
bridge 1 route ip
control-plane
line con 0
line aux 0
line vty 0 4
login
line vty 5 15
login
end
