Cisco 2800 series - IPV6 support
vrajkumar09
   What is the IOS version that supports IPV6 routing and flow export support for Cisco 2800 series.
Current version:
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 06-Nov-06 03:00 by alnguyen
Raj
Calin C.
Level 5
Level 5
Hello Raj,
Depending on the Features Set, there are more than one. I can suggest:
12.4(15)T13
c2801-adventerprisek9-mz.12.4-15.T13
You need minimum 192 RAM and 64 Flash for this image.
If you have a CCO account you can use Software Advisor to check for an IOS with the features that you want.
Your actual image doens't support IPv6?
Cheers,
Calin
