Bandwidth (QOS) command is not taking in the Giga interface
smartboy2255
HI all,
  While applying service policy command in out direction in cisco 7609 Router, I am getting following error. "bandwidth percent command is not supported in output direction for this interface Configuration failed!".Even I have changed the bandwidth percentage command to Kbps value.Then also I am getting error.
class-map match-any TESTQOS
  match access-group name testdata
class-map match-all test1
  match access-group 2005
Class-map default
fair que
policy-map QOS
  class TESTQOS
   bandwidth percent 40
    class test1
   bandwidth percent 20
ip access-list extended testdata
permit ospf any any
permit esp any any
Service-policy output QOS
Thanks a lot in advance....
Mahesh
smartboy2255
sorry pls find the error...
testrouter(config)#int Gi2/5
testrouter(config-if)#service-policy output QOS
