Cisco 2800 Series Router IOS is not loading
abdul.imran523
Please help me i have one cisco router 2811 now its not booting normally.
Router was working without any problems but due to power loss router restarted and goes into rommon mode
I tried to boot from flash and usbfalsh with different images but no use router is in still rommon mode.
here the output of my router:
program load complete, entry point: 0x8000f000, size: 0x3117470
Error : compressed image checksum is incorrect 0x8E095E7F
        Expected a checksum of 0x8E0AE77F
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x80014e20
PC = 0x8000f0d4, Cause = 0x20, Status Reg = 0x3040a803
c2811 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
monitor: command "boot" aborted due to user interrupt
rommon 1 > dir flash:
Directory of flash:
2      51475984  -rw-     c2800nm-advipservicesk9-mz.124-15.T10.bin
12570    52667880  -rw-     c2800nm-adventerprisek9-mz.124-15.T1.bin
rommon 2 > boot flash:c2800nm-adventerprisek9-mz.124-15.T1.bin
program load complete, entry point: 0x8000f000, size: 0x323a448
Error : compressed image checksum is incorrect 0x07A4628E
        Expected a checksum of 0x07A5B38E
open(): Open Error = -13
loadprog: error - on file open
boot: cannot load "flash:c2800nm-advsecurityk9-mz.124-15.T10.bin"
Error : compressed image checksum is incorrect 0x8E09407F
Error : compressed image checksum is incorrect 0x8E09327F
Error : compressed image checksum is incorrect 0x8E09E07F
Error : compressed image checksum is incorrect 0x8E09847F
Entering rommon> prompt after several failed attempts to boot an IOS image.
Please check your internal/external flash drives for the correct IOS image
and issue 'reset' at the rommon> prompt to re-try the boot process.
rommon 1 >
8 Replies 8
Leo Laohoo
Power down the router.
Remove all WIC and NM card.
Power up the router.
Please be informed that we dont have WIC cards
i dont know how to remove NM Card.
Since there are two images in flash and attempts to load each of them report that the image is not valid suggest that there may be an issue with flash on this router. If the router is under a maintenance contract I would suggest that you open a case with Cisco TAC.
If a TAC case is not an option I would ask if you have an image for this router on a PC somewhere. If you do have an image then I would suggest using the tftpdnld command on the router in rommon to load and run the image from a tftp server on the PC that has the image. This could get the router up and running and make additional diagnostics available.
Rick
Rick
Hi ,
I tried usbflashdisk and tftpdnld commands also but the result is same.
Are you saying that you used the tftpdnld and got an error message that the checksum was incorrect? That would be highly unusual. Can you post the console messages generated during the use of tftpdnld?
Rick
Rick
You CANNOT boot an IOS from a USB flash if you have never upgraded the bootstrap.
If all else fails, contact Cisco TAC and get your router RMA-ed.
Uns_crew and pull out the NM out of the router.
Exactly what NM cards do you have?
i also face this error but it is resolved when i change RAM, therefore i think this is problem or uncompetibilty
of RAM and u need to change ur RAM.
