Which training course for BGP
carl_townshend
Hi All
which is the best traning course to go on to learn about BGP, I did CCNP Route a while back, The BGP course was retired so is there a replacement for this?
would it be the CSPROUTE ?
I would like to learn BGP in depth
Cheers
Carl
5 Replies 5
Hello
Please check the below links, they will be alot cheaper than going ona course and always accessible for your review.
http://www.amazon.com/Internet-Routing-Architectures-2nd-Edition/dp/157870233X
http://www.amazon.com/Routing-Volume-CCIE-Professional-Development/dp/1578700892/ref=pd_bxgy_b_text_y/190-0560606-3989234
http://www.cisco.com/en/US/tech/tk365/technologies_q_and_a_item09186a00800949e8.shtml
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Hi There
I would rather go on the training, which course is most suitable for this ?
Carl,
You can look at CBTNuggets (although I find them to be a huge joke), Cisco NetAcademy, and or CCNP/CCIE training courses online will cover BGP. You can also look up Boson training etc.
But, I have to agree with pdriver, it would be cheaper and IMO a whole let better for you, if you got some kindle books or books from the links he posted above.
But which ever method works best for you, I would do.
IMHO, the most effective way is to read some BGP books first, then play with it a lab for a basic understanding.
THEN to go for a training and use it to raise questions.
And finally to review the traing materials in a lab again.
Best regards,
Milan
hi carl,
go for CCNA SP SPNGN2 (640-878) exam if you want to get started with BGP.
http://www.cisco.com/web/learning/exams/docs/640-878_spngn2.pdf
SPROUTE is CCNP level.
for trainings, go this to link:
http://tools.cisco.com/GlobalLearningLocator/courseDetails.do?actionType=executeCourseDetail&courseID=5779&keyWordSearched=TRN-SPNGN2
the CLN is basically your best friend. good luck!
