Cisco 2801 error on fa0/1 "Phy reset failed"
sadcock123
just wondering if anyone has come across the error before?
The interface is connected to a Adva 150 (BT EAD NTE) which is not showing up according to BT who are looking at the NTE.
This error occurs when I ammend the speed/duplex of the Cisco router, but not come across this in the past.
Below is the config as seen on fa0/1:-
interface FastEthernet0/1
bandwidth 10240
no ip address
no ip redirects
speed 100
full-duplex
interface FastEthernet0/1.3034
description MONITORED-INTERFACE BT ETHXXXXXX
encapsulation dot1Q 3034
ip address x.x.x.x x.x.x.x
The IOS version running is 12.4 (25b).
Any advice or help on this would be much appreciated.
Kind regards
Steven
Yes, chances are, you have a faulty unit.
8 Replies 8
paolo bevilacqua
Can you send show interface ?
Did it ever worked before?
Hello Paolo,
please see the interface below:-
sh interfaces fa0/1
FastEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is ec44.7637.5c3d (bia ec44.7637.5c3d)
MTU 1500 bytes, BW 10240 Kbit/sec, DLY 100 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:24:11, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
46723 packets output, 4405621 bytes, 0 underruns
0 output errors, 0 collisions, 19 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
Also to answer your question on has it ever worked, I believe this is a new router from our supplier (BTinet).
Cheers
Steven
I would start replacing the cable. If still trouble, have ISP replace whatever is their equipment.
Then of course, it's also possible that the router is faulty.
If I do a show controllers in fa0/1 the below looks odd:-
PHY registers:
  Register 0x00:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x08:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x10:   FFFF  FFFF  FFFF  FFFF        FFFF  FFFF  FFFF
  Register 0x18:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
I will continue with replacing the cable and liasing with the provider.
Going to also raise this with my supplier who sold me the router.
Kind Regards
Steven
Thank you.
I will keep you posted on the outcome.
Kind Regards
Steven
Just to let you know it seems to be a faulty unit.
I have patched the cable into a 1801 and everything works fine (used same cable/same NTE).
We are now raising this with our supplier.
Thank you for your help.
Kind Regards
Steven
You are welcome, thank you for the nice rating, and good luck!
