Cisco 2801 VWIC Frame Relay Layer 2 problem interface up/down lmi deleted
elvinmorales
I need a another set of eyes on this issue. I am building a frame relay cloud with a 3725 as the frame relay switch, 2 2691 as remote sites and 1 2801 as the other remote site. The 2691s are working and connected but the 2801 interface stays in an up/down state, LMI status is deleted and the LMI debugs just shows DCE LMI timeout on the Frame relay switch. I have swapped cards, cables and even routers. I used the same config on another 2801 and I get equal results. I am running IOS 15.1 on the 2801. Please view the configs attached. I configured the same dlci on a spear interface on a 2691 and it worked I believe there maybe something I need to make this work on the 2801 on 15.1 that I am not aware of.
10 Replies 10
Please show us serial interface configuration and show frame-relay lmi and show frame-relay pvc
Please review the requested output below. I have confirmed LMI type and encapsualtion.
ROUTER_BR2#sh frame-relay pvc
PVC Statistics for interface Serial0/1/0:0 (Frame Relay DTE)
              Active     Inactive      Deleted       Static
  Local          0            0            1            0
  Switched       0            0            0            0
  Unused         0            0            0            0
DLCI = 102, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0/1/0:0.1
  input pkts 0             output pkts 3            in bytes 0
  out bytes 240            dropped pkts 0           in pkts dropped 0
  out pkts dropped 0                out bytes dropped 0
  in FECN pkts 0           in BECN pkts 0           out FECN pkts 0
  out BECN pkts 0          in DE pkts 0             out DE pkts 0
  out bcast pkts 3         out bcast bytes 240
  pvc create time 00:12:34, last time pvc status changed 00:11:48
ROUTER_BR2#
ROUTER_BR2#sh frame-relay lmi
LMI Statistics for interface Serial0/1/0:0 (Frame Relay DTE) LMI TYPE = ANSI
  Invalid Unnumbered info 0             Invalid Prot Disc 0
  Invalid dummy Call Ref 0              Invalid Msg Type 0
  Invalid Status Message 0              Invalid Lock Shift 0
  Invalid Information ID 0              Invalid Report IE Len 0
  Invalid Report Request 0              Invalid Keep IE Len 0
  Num Status Enq. Sent 72               Num Status msgs Rcvd 0
  Num Update Status Rcvd 0              Num Status Timeouts 71
  Last Full Status Req 00:00:09         Last Full Status Rcvd never
ROUTER_BR2#
Serial0/1/0:0 is up, line protocol is down
  Hardware is GT96K Serial
  MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
  Encapsulation FRAME-RELAY IETF, loopback not set
  Keepalive set (10 sec)
  LMI enq sent  45, LMI stat recvd 0, LMI upd recvd 0, DTE LMI down
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0
  LMI DLCI 0  LMI type is ANSI Annex D  frame relay DTE
  FR SVC disabled, LAPF state down
  Broadcast queue 0/64, broadcasts sent/dropped 3/0, interface broadcasts 3
  Last input never, output 00:00:09, output hang never
  Last clearing of "show interface" counters 00:07:45
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     16930 input errors, 9832 CRC, 2 frame, 6 overrun, 0 ignored, 7090 abort
     49 packets output, 884 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     1 carrier transitions
  Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
Serial0/1/0:0.1 is down, line protocol is down
  Internet address is 10.10.33.130/25
--------------------------------------OUTPUT From the FR Switch---------------------------------------------------------------------------
PSTN_WAN#sh frame-relay lmi
LMI Statistics for interface Serial0/0:1 (Frame Relay DCE) LMI TYPE = ANSI
  Num Status Enq. Rcvd 83               Num Status msgs Sent 83
  Num Update Status Sent 0              Num St Enq. Timeouts 0
LMI Statistics for interface Serial0/1:1 (Frame Relay DCE) LMI TYPE = ANSI
LMI Statistics for interface Serial0/2:1 (Frame Relay DCE) LMI TYPE = ANSI
  Num Status Enq. Rcvd 0                Num Status msgs Sent 0
  Num Update Status Sent 0              Num St Enq. Timeouts 56
PSTN_WAN#sh frame
PSTN_WAN#sh frame-relay pvc
PVC Statistics for interface Serial0/0:1 (Frame Relay DCE)
  Local          0            0            0            0
  Switched       1            1            0            0
  Unused         0            0            0            0
DLCI = 201, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE = Serial0/0:1
  input pkts 130           output pkts 343          in bytes 15869
  out bytes 28560          dropped pkts 0           in pkts dropped 0
  out bcast pkts 0         out bcast bytes 0
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
  switched pkts 128
  Detailed packet drop counters:
  no out intf 0            out intf down 0          no out PVC 0
  in PVC down 0            out PVC down 0           pkt too big 0
  shaping Q full 0         pkt above DE 0           policing drop 0
  pvc create time 00:17:02, last time pvc status changed 00:16:42
DLCI = 202, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial0/0:1
  input pkts 7             output pkts 0            in bytes 1337
  out bytes 0              dropped pkts 0           in pkts dropped 0
  switched pkts 5
  pvc create time 00:17:03, last time pvc status changed 00:16:13
PVC Statistics for interface Serial0/1:1 (Frame Relay DCE)
  Local          0            0            0            0
  Switched       1            0            0            0
  Unused         0            0            0            0
DLCI = 101, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE = Serial0/1:1
  input pkts 358           output pkts 132          in bytes 30700
  out bytes 16041          dropped pkts 0           in pkts dropped 0
  switched pkts 353
  pvc create time 00:17:27, last time pvc status changed 00:17:06
PVC Statistics for interface Serial0/2:1 (Frame Relay DCE)
  Local          0            0            0            0
  Switched       1            0            0            0
  Unused         0            0            0            0
DLCI = 102, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE = Serial0/2:1
  input pkts 0             output pkts 5            in bytes 0
  out bytes 918            dropped pkts 0           in pkts dropped 0
  switched pkts 0
  pvc create time 00:17:30, last time pvc status changed 00:17:08
PSTN_WAN#
Serial0/2:1 is up, line protocol is down
  Description: FR to BR2
  MTU 1500 bytes, BW 1344 Kbit/sec, DLY 20000 usec,
  LMI enq sent  0, LMI stat recvd 0, LMI upd recvd 0
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0, DCE LMI down
  LMI DLCI 0  LMI type is ANSI Annex D  frame relay DCE
  Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:18:43
     Received 0 broadcasts, 0 runts, 2 giants, 0 throttles
     16 input errors, 1 CRC, 0 frame, 1 overrun, 0 ignored, 12 abort
     5 packets output, 918 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     2 carrier transitions
sukanyachavan
Can you please give us output of
show frame-relay route ON FR Switch
Sukanya
elvinmorales
PSTN_WAN#sh frame-relay route
Input Intf      Input Dlci      Output Intf     Output Dlci     Status
Serial0/0:1     201             Serial0/1:1     101             active
Serial0/0:1     202             Serial0/2:1     102             inactive
Serial0/1:1     101             Serial0/0:1     201             active
Serial0/2:1     102             Serial0/0:1     202             active
PSTN_WAN#
Can you please provide output of "show controller" of all devices.
Editted: Also, as of now most of your config looks correct. Can you check/swap cable just to make sure that cables are not at fault.
Smitesh
ROUTER_BR2#sh controller
ROUTER_BR2#sh controllers t1
T1 0/1/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20090113, FPGA: 20, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (52 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 2 15 minute intervals):
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
ROUTER_BR2#
HQ_RTR#sh controllers t1
T1 0/0 is up.
  No alarms detected.
  Version info Firmware: 20041023, FPGA: 16, spm_count = 0
  Data in current interval (892 seconds elapsed):
     105 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     105 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 1 15 minute intervals):
     105 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
BR1_RTR#sh controllers t1
T1 0/0 is up.
  No alarms detected.
  Data in current interval (23 seconds elapsed):
     3 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     3 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
     241 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     241 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
PSTN_WAN#sh controllers t1
T1 0/0 is up.
  No alarms detected.
  Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
  Data in current interval (196 seconds elapsed):
T1 0/1 is up.
  No alarms detected.
  Data in current interval (199 seconds elapsed):
T1 0/2 is up.
  No alarms detected.
  Data in current interval (201 seconds elapsed):
FYI... I have added Netwok-clock-select to BR1 and HQ routers and controllers are crispy clean, I have also swapped cards, cables and this is the second 2801 I have tested. Thanks for your help.
Thanks to everyone for assisting.
I have found and resolved the problem. The cisco 3725 and 2691s apparently use 56k timeslots and the 2801 use 64k slots. So on the cisco 3725 controller I entered channel-group 1 timeslots 1-24 speed 64. The "speed 64" is necessary to match the 2801.
Serial0/0:1     202             Serial0/2:1     102             active
PSTN_WAN#
Nice!!
I had the same problem and then I changed the speed to 64 on my 3745 and boom... my frame-relay interfaces came up!!! Thank you very much for sharing this information, don't know if I could have done it with this...
Thanks for bringing this thread back to life Rashad!  I  have been wrecking my brain on this one for a while now with my 3725.
