Cisco 2811 NAT Issues
mikebry99
Having some problems with NAT between our Office and Co-Location. I have attached the details.
Basically we have 2 cisco 2811 routers connected over a bonded T1 connection. Private IP addresses on each end 10.58.0.2/30 <-> 10.58.0.1/30 . We have NAT enabled at the 10.58.0.2/30 router to get out to the internet and for access back into our servers using static nat . The problem is when we ping a device from the 10.58.0.2 to 10.58.0.1 it returns a public IP address instead of the private 10.58.3.0/24 that we want.
I can not turn off NAT on the 10.58.3.0/24 interface otherwise we lose internet connectivity and outside access in.
Can someone please help? How can we stop the translation in that direction?image.png
You can try denying nat-ing the trafic between 10.58.x.x traffic :
no ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source list NAT interface FastEthernet0/0 overload
ip access-list ex NAT
deny ip 10.58.0.0 0.0.255.255 10.58.0.0 0.0.255.255
permit ip 10.58.0.0 0.0.255.255 any
Dan
mikebry99
Here is the Config:
ip name-server 216.251.xxx.xxx
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FHK1446F2CP
redundancy
description $ETH-WAN$
ip address 216.251.xxx.xxx 255.255.255.240 secondary
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.58.0.1 255.255.255.252
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/0
ip address 10.58.3.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/2/0
description $ES_LAN$
ip address 10.58.8.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip default-gateway 216.251.xxx.xxx
ip forward-protocol nd
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 216.251.xxx.xxx
ip route 10.58.0.0 255.255.192.0 FastEthernet0/1
ip route 10.58.66.0 255.255.255.0 FastEthernet0/1
ip route 10.58.68.0 255.255.255.0 FastEthernet0/1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.58.0.0 0.0.0.3
access-list 1 permit 10.58.3.0 0.0.0.255
access-list 1 permit 10.58.8.0 0.0.0.255
access-list 1 permit 10.58.66.0 0.0.0.255
access-list 1 permit 10.58.68.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
line vty 5
scheduler allocate 20000 1000
end
Dan
Thank you Dan! That worked.
