Cisco 2811 with High CPU usage
NetBegv85
Hello
My router 2811 have high cpu usage (80%)
I haven't debug on my router.
When I take show proc cpu, the list of processes total up to less then 10%
I have lot of access-list (150) and 600 lines for it.
I have policy map for ftp, visio, P2P, smtp, ...
I have 15 ip inspect
100 Mb/s for the lan interface and 10Mb/s for the wan
I search command for see who is using the cpu.
rfalconer.sffcu
Level 3
Level 3
Did you run 'sh proc cpu sorted' to see what's the highest process?
Is the high utilization constant?
It's possible that your ACLs/Policy Maps are causing high CPU utilization due to interrupts.
Are you getting hits on all the ACLs and all elements in those ACLs?
Lei Tian
The show pro CPU output tells you most CPU cycle are on interrupt level. You are giving too much works to the router:) There isn't a command to show process under interrupt; I think you have to do CPU profile to find out that information.
http://www.itcertnotes.com/2011/03/cisco-router-cpu-profiling.html?m=1
HTH,
Lei Tian
