04-03-2013 11:01 PM - edited 03-04-2019 07:29 PM
Hi there
Would the above router be a good choise for a home office setup for use with WAN speeds upto 30Mbps and VOIP?
Any other, preferable serjestionns welcomed?
Thanks in advance for any input.
G ; )
Solved! Go to Solution.
04-04-2013 01:07 AM
With 2821 you will be able to go up to 87Mbps.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
This router should handle everything you need for home office and VoIP.
Best Regards
Please rate all helpful posts and close solved questions
04-04-2013 01:07 AM
Best Regards
