Cisco 2821 - Unable to access certain websites
leacho73
Hi All,
I have recently commissioned a Cisco 2821 router as a boundary router for my network - my PPPoE connection is connecting fine, and being assigned an IP - I have my NAT statements set up and I can ping from my internal test machine out to any website address I choose - however, when I try and load a webpage - unless it is google or facebook, the page times out.
Config is:
Building configuration...
Current configuration : 1814 bytes
version 12.4
service password-encryption
hostname Router01
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name local
no ipv6 cef
voice-card 0
username <redacted>
archive
 log config
  hidekeys
ip ssh time-out 60
ip ssh source-interface GigabitEthernet0/1
ip ssh version 2
ip ssh dh min size 4096
interface GigabitEthernet0/0
 description Internet
 no ip address
 ip tcp adjust-mss 1452
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
 description Internal
 ip address 192.168.0.1 255.255.255.248
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface Dialer1
 ip address negotiated
 no ip unreachables
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp chap hostname <redacted>
 ppp chap password <redacted>
 ppp pap sent-username <redacted>
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.0.0 0.0.0.255
Not sure what is going on. Its worth noting that DNS requests are also working just fine.
Matt
amikat
Will you please move the configuration command "ip tcp adjust-mss 1452" under the "interface Dialer1".
Best regards,
Antonin
waqas.salam
if you able to ping public IP's ,then you need to resolve www.facebook.com on CMD by having
nslookup www.facebook.com
Server: UnKnown
Address: 192.168.1.1
Non-authoritative answer:
Addresses: 2a03:2880:f108:83:face:b00c:0:25de
31.13.86.36
Aliases: www.facebook.com
if you able to resolve above then plz check browser setting.
As above ^^ - DNS requests resolve just fine
amikat
Best regards,
Antonin
