Cisco 2900 router keeps loosing internet connection
bhattdarsh
Our cisco 2911 router keeps loosing Internet connection every month or two. When I checked the lights on the router, all lights were ON except "activity" light. I think router is getting freeze or something. I always have to reboot the router to bring it back ON. I can't check the logs either as we don' t have syslog server and after reboot, router erases all the logs. Has anyone experienced this kind of issue before? or does anyone know the solution?
Thanks in advance.
11 Replies 11
mvsheik123
Level 7
Level 7
Hi Darshan,
When it 'freezes' - did you try to log in (console/ssh/telnet) and check the router logs, CPU usage etc? hat information may help you fix the issue.
Thx
MS
Hi MS,
When it freezes, I can't login to router via console/ssh/telnet. Becauase it goes offline.
Leo Laohoo
Post the output to the following command:  sh interface
Embedded-Service-Engine0/0 is administratively down, line protocol is down
  Hardware is Embedded Service Engine, address is 0000.0000.0000 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Input queue: 0/64/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 7c69.f629.fd08 (bia 7c69.f629.fd08)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  5 minute input rate 53000 bits/sec, 40 packets/sec
  5 minute output rate 14000 bits/sec, 15 packets/sec
     116539 packets input, 18886287 bytes, 0 no buffer
     Received 93015 broadcasts (5713 IP multicasts)
     0 watchdog, 46792 multicast, 0 pause input
     41926 packets output, 5054872 bytes, 0 underruns
     110 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/0.1 is up, line protocol is up
  Internet address is 10.20.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1.
GigabitEthernet0/0.21 is up, line protocol is up
  Internet address is 10.21.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  21.
GigabitEthernet0/0.22 is up, line protocol is up
  Internet address is 10.22.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  22.
GigabitEthernet0/0.23 is up, line protocol is up
  Internet address is 10.23.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  23.
GigabitEthernet0/0.24 is up, line protocol is up
  Internet address is 10.24.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  24.
GigabitEthernet0/0.25 is up, line protocol is up
  Internet address is 10.25.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  25.
GigabitEthernet0/0.26 is up, line protocol is up
  Internet address is 10.26.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  26.
GigabitEthernet0/0.27 is up, line protocol is up
  Internet address is 10.27.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  27.
GigabitEthernet0/0.28 is up, line protocol is up
  Internet address is 10.28.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  28.
GigabitEthernet0/0.29 is up, line protocol is up
  Internet address is 10.29.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  29.
GigabitEthernet0/0.30 is up, line protocol is up
  Internet address is 10.30.0.3/16
  Encapsulation 802.1Q Virtual LAN, Vlan ID  30.
GigabitEthernet0/1 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 7c69.f629.fd09 (bia 7c69.f629.fd09)
  Internet address is 115.70.207.75/31
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Half Duplex, 100Mbps, media type is RJ45
  Last input 00:00:02, output 00:00:05, output hang never
     594 packets input, 47340 bytes, 0 no buffer
     Received 220 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     773 packets output, 83263 bytes, 0 underruns
GigabitEthernet0/2 is administratively down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is 7c69.f629.fd0a (bia 7c69.f629.fd0a)
  Auto Duplex, Auto Speed, media type is RJ45
Dialer0 is up (spoofing), line protocol is up (spoofing)
  Hardware is Unknown
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  DTR is pulsed for 1 seconds on reset
NVI0 is up, line protocol is up
  Hardware is NVI
  Interface is unnumbered. Using address of GigabitEthernet0/0.1 (10.20.0.3)
  MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
  Encapsulation UNKNOWN, loopback not set
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Ok, so it's a DSL link.  Then post this command:  sh atm interface
The router is not recognising this command.
Do you have a DSL model in front of the router?
You mean DSL modem. if so then yes, modem is connected to the router.
Because you have a DSL modem this makes troubleshooting a bit harder.  With a DSL modem and your router acting as a pass-through it is very difficult to determine if your copper line is degraded.
If you are able to somehow pull the NOISE and ATTENUATION value off the DSL modem that would be a good start.
Ashish Arora
Darshan,
I looked at the thread and checked the configuration. There could be couple of potential reasons for this problem :however I would like you to plrEase answer the following:-
1. As per the configuration ,it seems like this setup is PPPoE in which things are connected as follow :-
  Router(fe)-----(fe)modem(atm/rj14)-----telco.
Correct me if wrong.
2. If step 1 is correct , which fe/ge interface connects to the router , send me the output of show run interface gig/fa and show run int dialer 0.
3. What I gonna check if this is a interface issue or router.,
Send me output of show interface gig(number).
4. In case if this is an intermittent issue , have you tried to replace the modem and monitor the behaviour ?
5.I will have to check any specific trap and then will create EEM script to check the outputs of debug pppoe events and debug PPP negotiation .
Thses debugs will help me to identify the cause of internet failure.
6. Since you reported issues only with internet when router freezes , I am hoping at the same instant you are not able to send local traffic across it , if yes please let me know what is evidence of claiming issues to the DSL only , are you facing anything on the modem or any suspeced activity which points to things it is a DSL issue.
7. You should also try to replace the router and see if that helps.
8. We can check any software vulnerability in the platform ,please share the show version output so that I can check the IOS version.
9.,since it is an intermittent , only action is to perform EEm and collect logs during issue occurance.
Thank you
Ashish Arora
usasigcis
Good steps
Also I d check for a possible bug in the code
Sent from Cisco Technical Support Android App
