Qos in sub interface
frank2812
Hi, i´m trying to emulate a QOS in a network in GNS3. I attached sh run  of both routers and the image where the cloud represents my computer. I´m trying to limit the traffic from 192.168.1.108 (my computer) in the link between routers to 512 kbps. The link between routers should be 4Mb maximun. im generating traffic from a traffic generator in my laptop and the QOS in the interface is not working. I´ll wait your answers
In sumary the confi in R1 and r2 is
COnfig R1
class-map match-any MARCAJE_ANTIVIRUS
match access-group name ANTIVIRUS
policy-map QOS-ANTIVIRUS
class MARCAJE_ANTIVIRUS
  priority 512
policy-map parent
class class-default
  shape average 4000000
  service-policy QOS-ANTIVIRUS
ip access-list extended ANTIVIRUS
permit ip  host 192.168.1.108 any
no permit ip  any  host 192.168.1.108
load-interval 30 dentro de la if fisica
interface FastEthernet0/1.800
description METROETHERNET-PRIVADO-CANTV
encapsulation dot1Q 800
ip address 10.10.10.4 255.255.255.0
no snmp trap link-status
service-policy output parent
bandwidth 4000
end
Config R2
  priority 512
policy-map parent
class class-default
ip address 10.10.10.2 255.255.255.0
bandwidth 4000
Hello
Try this:
class-map match-all MARCAJE_ANTIVIRUS
class-map match-all DSCP
match  dscp 2
policy-map Child
class DSCP
bandwidth 512
random-detect
class class-default
fair-queue
policy-map parent
class class-default
service-policy Child
police 512000 80000 conform-action transmit  exceed-action drop
set dscp 2
interface FastEthernet0/0
service-policy input QOS-ANTIVIRUS
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
5 Replies 5
Nagendra Kumar Nainar
Hi Frank,
Per you configuration, you have 4 MB of total traffic allowed and anything more will be buffered. Also yo have a child policy applied to match the traffic from you PC and have it in LLQ. So when there is no traffic on otehr classes (in your case class-default whihc will have the remaining bandwidth), traffic in LLQ can go uptil the shapoing rate whcih is 4 MB.
The above coniguration will allow 4 Mb of traffic from you PC. If your intension is to limit the traffic from PC less than 512 Kb, you need to apply policing to match the traffic from PC and police @ 512 Mb.
HTH,
Nagendra
i think when i put "policy-map QOS-ANTIVIRUS" i´m doing policing to match the traffic from PC. Could you explain me in more detail?
  priority 512
Hello
You can mark on the interface for the traffic ingress from.your pc and match on and apply Llq to this traffic outbound on the egress interface between your two routers
Or
Police all the ingress traffic from the pc before it hits the wan interface and then shape your overall.traffic to.your CIR
Res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
usasigcis
Negative you re prioritizing thst traffic kf there is a congestion
As explained above if there is enough bw 4mb will be used
Yiu need to jse police command rsther than priority
Hello
Try this:
match  dscp 2
policy-map Child
class DSCP
bandwidth 512
random-detect
class class-default
fair-queue
policy-map parent
class class-default
set dscp 2
res
Paul
Thanks.
Kind Regards
Paul
