Cisco 2900 Series
Dear All,
Kindly confirm if the Cisco 2901 capable for wan connection with bandwidth 100.0Mbps upload and 100.0Mbps download or 200.0 Mbps total throughput
5 Replies 5
omz
Simple answer - yes
All onboard WAN ports are 10/100/1000 Gigabit Ethernet WAN routed ports.
Depending on the module check data sheet.
https://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html
Thanks on your immediate reply,
i found this---The Cisco 2900 Series enables deployment in high speed WAN environments with concurrent services enabled up to 75 Mbps. --- in data sheet
Leo Laohoo
See attachment.
2901 can support up to 167.42 Mbps in raw performance.
This value is expressed in a COMBINED SINGLE DIRECTION (upload or download).  It is also expressed without any encryption happening.
Thank you sir, how about the throughtput of 4351?
Between 200- to 400 Mbps.  Again, single direction and no encryption.
