CISCO 2900 Series
Pranab-ICAI
How to get License renewal of CISCO 2900 Routers
hemohemoh
Hi Pranab,
Probably you should refer back to your Reseller / Vendor and ask for the price.
ammahend
you can not, its end of life and end of support. you can continue using at your own risk or upgrade with the replacement part number listed below
https://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/eos-eol-notice-c51-737831.html
-hope this helps-
