Cisco 2901 access-list block - HELP
tsrader
Outside Customer Router
GigabitEthernet0/0 192.168.0.1 YES manual up up
GigabitEthernet0/1 10.10.100.11 YES manual up up
Internal Router
GigabitEthernet0/0         192.168.0.2     YES manual up                    up
GigabitEthernet0/1         172.16.201.1    YES manual up                    up
External host ip:  10.10.100.110
Internal host ip:  172.16.201.110
Here is my issue:
deny all inside-to-outside traffic
permit external host access to internal host but BLOCK everything else
My attempt on blocking ACL does not work.
access-list 110 deny   ip 192.0.0.0 0.0.0.255 any
access-list 110 deny   ip 224.0.0.0 0.0.31.255 any
access-list 110 deny   ip 10.0.0.0 0.255.255.255 any
access-list 110 deny   ip 172.16.0.0 0.15.255.255 any
access-list 110 permit tcp host 10.10.100.110 host 172.16.201.110
access-list 110 permit ip any any
interface gi0/???
THIS IS TO BE APPLIED TO INTERNAL ROUTER ONLY.
Any help is appreciated.
John Blakley
Reflexive acl may be able to be used here. I had responded and realized that I had interfaces wrong, so rather than editing a whole post I just deleted to start over.
Try the following on your internal router:
ip access-list ext Allowed
permit tcp host 10.10.100.110 host 172.16.201.110 reflect InOut
deny ip any any
ip access-list ext InOut
evaluate InOut
deny ip any any
int g0/1
ip access-group Allowed out
ip access-group InOut in
See if that works for you...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
The best way to achieve this is to configure an IOS-firewall on your router. But for that you need the "security" license.
