Cisco 2901 and ARP
ckxen8401
Hello, I recently purchased a 2901, I used to run an 1811. I'm trying to figure out if the reason I can't seem to get the ARP configuration working correctly.
I register to my Charter Fiber WAN using a static address 24.XXX.XXX.XXX. I have a static pool (68.XXX.XXX.100 - 68.XXX.XXX.105) assigned by Charter, used for servers. On my 1811 anyone attempting to reach my static pool has no issues. If I were to browse http://www.whatsmyip.org on this router, depending on what server i'm on, I will see an address of 68.XXX.XXX.XXX. This is what I expect to happen.
However, on my 2901 this fails. Internally the 68.XXX.XXX.XXX network works perfectly, I can echo and load any servers, however on the WAN side this network doesn't exist, and any attempt to use a 68 address server fails. If I were to browse http://www.whatsmyip.org, no matter what server i'm on, I will see an address of 24.XXX.XXX.XXX. Is this just a difference in models? It would seem by default ARP is setup on the 2901.
Cisco 2901 configuration
Building configuration...
Current configuration : 2350 bytes
! Last configuration change at 08:36:19 UTC Mon Oct 6 2014
version 15.2
service password-encryption
hostname Cisco2901
boot-start-marker
boot-end-marker
enable secret 5 supersecretpassword
enable password 7 supersecretpassword
no aaa new-model
ip cef
ip dhcp excluded-address 68.XXX.XXX.100
ip dhcp pool DHCP_Pool
 network 68.XXX.XXX.099 255.255.255.248
 default-router 68.XXX.XXX.100
 dns-server 8.8.8.8 8.8.4.4
 class DHCP_Class
  address range 68.XXX.XXX.100 68.XXX.XXX.105
ip dhcp class DHCP_Class
no ipv6 cef
license udi pid CISCO2921/K9 sn FTX1828AKAY
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 24.XXX.XXX.XXX 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface GigabitEthernet0/1/4
 no ip address
interface GigabitEthernet0/1/5
 no ip address
interface GigabitEthernet0/1/6
 no ip address
interface GigabitEthernet0/1/7
 no ip address
interface Vlan1
 ip address 68.XXX.XXX.100 255.255.255.248
 ip nat inside
router rip
 network 68.0.0.0
ip default-gateway 68.XXX.XXX.100
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list InternetAccessList interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip access-list standard InternetAccessList
 permit 68.XXX.XXX.0 0.0.0.255
snmp-server community WWM_Cisco2901 RO
snmp-server enable traps entity-sensor threshold
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Show arp
Internet  24.XXX.XXX.XXX -  f8c2.8869.fbe0  ARPA   GigabitEthernet0/0
Internet  68.XXX.XXX.100  -  f8c2.8869.fbe3  ARPA   Vlan1
Richard Burts
The title of the post suggests that there might be issues about ARP. But I do not see anything in the text of the post that indicates any issue with ARP.
I do not know how your old router was configured or how it worked. But the cause of your current issue is pretty clear. You have configured the router to perform address translation for any 68.x.x.x traffic going out the Internet interface
If you do not want the addresses to be translated on the way out then remove the ip nat statement.
Rick
Rick
Richard Burts
Rick
Rick
Thanks, it worked perfectly. I'm still learning Cisco ios, so forgive the noobness.
