Wired and wireless access within a multiple SSID 887W router
bprietoclv
I have configured my 877W router with two SSIDs, one for work and the other one for guest access and both of them works fine, but when I try to connect a wired computer, which I'd like to use guest ip range,  none of the fastethernet ports seems to work (neither with fixed IP address nor dynamic). This is my current interface configuration:
version 12.4
no service pad
service timestamps debug datetime msec localtime year
service timestamps log datetime msec localtime year
service password-encryption
service compress-config
dot11 syslog
dot11 vlan-name vlan101 vlan 101
dot11 vlan-name vlan102 vlan 102
dot11 ssid WOLOLO
 authentication open
 authentication key-management wpa
 guest-mode
 wpa-psk ascii ***
dot11 ssid WOLOLO.Guest
 vlan 102
 max-associations 10
 authentication open
 guest-mode
 wpa-psk ascii ***
dot11 ssid WOLOLO.Home
 vlan 101
 max-associations 2
 authentication open
 wpa-psk ascii ***
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.15
ip dhcp excluded-address 10.25.1.9
ip dhcp pool dhcp_vlan102
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 80.58.61.250 8.8.4.4
   lease 30
ip dhcp pool dhcp_vlan101
   network 10.25.1.8 255.255.255.248
   default-router 10.25.1.9
   dns-server 172.21.232.42 172.21.232.43
   lease 30
bridge irb
interface ATM0
 no ip address
 no atm ilmi-keepalive
 pvc 8/32
  encapsulation aal5snap
  protocol ip inarp
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 101 mode ciphers tkip
 encryption vlan 102 mode ciphers tkip
 ssid WOLOLO.Guest
 ssid WOLOLO.Home
 speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
interface Dot11Radio0.101
 encapsulation dot1Q 101
 no ip route-cache
 no cdp enable
 bridge-group 101
 bridge-group 101 subscriber-loop-control
 bridge-group 101 spanning-disabled
 bridge-group 101 block-unknown-source
 no bridge-group 101 source-learning
 no bridge-group 101 unicast-flooding
interface Dot11Radio0.102
 encapsulation dot1Q 102 native
 no ip route-cache
 no cdp enable
 bridge-group 102
 bridge-group 102 subscriber-loop-control
 bridge-group 102 spanning-disabled
 bridge-group 102 block-unknown-source
 no bridge-group 102 source-learning
 no bridge-group 102 unicast-flooding
interface Vlan1
 no ip address
interface Vlan101
 no ip address
 bridge-group 101
interface Vlan102
 no ip address
 bridge-group 102
interface Dialer0
 ip ddns update hostname razpiroz.no-ip.info
 ip ddns update no-ip
 ip address negotiated
 no ip proxy-arp
 ip accounting output-packets
 ip mtu 1420
 ip nat outside
 ip virtual-reassembly
 encapsulation ppp
 no ip route-cache
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname adslppp@telefonicanetpa
 ppp chap password ***
 ppp pap sent-username adslppp@telefonicanetpa password ***
 ppp timeout retry 30
 crypto map topix
interface BVI101
 ip address 10.25.1.9 255.255.255.248
 ip directed-broadcast
 ip nat inside
 ip tcp adjust-mss 1380
interface BVI102
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip forward-protocol udp
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
bridge 101 protocol ieee
bridge 101 route ip
bridge 102 protocol ieee
bridge 102 route ip​
2 Accepted Solutions
What does show vlan-sw br tell you? Are you able to add the vlan by typing vlan 102?
Ah now I see. You probably need to upgrade license on IOS. Will need advipservices to run multiple VLANs on 800 series. You can check current by using sh ver
9 Replies 9
Babak KHorshid
Are they trunk by default or on Vlan 1?  I think you better assign vlan 102 to these ports and then try it again to see if you are able to get IP address from the dhcp.
If I try to assign vlan 102, which is the one that I want, I get the following error:
router(config)#int fa0
router(config-if)#switchport mode access
router(config-if)#switchport access vlan 102
Vlan can not be added. Maximum number of 2 vlan(s) in the database.
Maybe this can help:
router#sh vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Fa0, Fa1, Fa2, Fa3
101  VLAN0101                         active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
101  enet  100101     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
router#sh vlans
Virtual LAN ID:  1 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interface:   Dot11Radio0
   Protocols Configured:   Address:              Received:        Transmitted:
        Other                                           0                  12
   0 packets, 0 bytes input
   12 packets, 1520 bytes output
Virtual LAN ID:  101 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interface:   Dot11Radio0.101
        Bridging        Bridge Group 101                0                   0
   0 packets, 0 bytes output
Virtual LAN ID:  102 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interface:   Dot11Radio0.102
 This is configured as native Vlan for the following interface(s) :
Dot11Radio0
        Bridging        Bridge Group 102              481               19403
   2254998 packets, 2198669877 bytes input
   19405 packets, 4977807 bytes output
What can see is that there is nothing related to vlan 102 on the output of show vlan-switch. In fact I have tried to configure vlan 101 (which is not the one that I want to configure) on the FastEthernet0 and it works and I can get dynamic IP from that network.
But what I really want to add is vlan 102 instead, which I can't :(
Sorry I missed the output for show vlan-sw above....
Instead of trying to input vlan 102 on the interface can you just type vlan 102?
Router#(config) vlan 102
Same error:
router(config)#vlan 102
I do not know why I can configure VLAN 101 instead of VLAN 102 if both of them has the same configuration. Maybe because, as show in the show vlans commands, VLAN 102 is configured as native Vlan for the Dot11Radio0 interface? Headaches!!!
Thank you so much Michael.
I will try to contact my reseller in order to get the IOS and move from advsecurity to advipservices. Meanwhile I will try to swap vlans 101 and 102 just to see if I can enable the one that I need on the wired ports. I will let you know.
Best regards,
Rafa.
That was the point. Change to advipservices. Thank you!!!
