Cisco 2901 NAT problem
tsrader
Problems trying to connect two Cisco 2901 routers together for LAN-to-LAN application.
Just trying to establish connection between PCs on both ends:
PC1:  172.16.201.110
PC2:  10.10.100.110
RTR_1 *
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 192.168.0.2 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.16.201.1 255.255.240.0
ip nat enable
duplex auto
speed auto
interface Vlan1
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 192.168.0.1
RTR_2 *
ip address 192.168.0.1 255.255.255.248
duplex auto
speed auto
ip address 10.10.100.50 255.255.255.0
ip nat enable
duplex auto
speed auto
interface Vlan1
no ip address
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 192.168.0.2
Any assistance is appreciated.
Are the default-gateways of the PCs set to 172.16.201.1 and 10.10.100.50? Then it should work. Your network is fully rouable and therefor there is no need to NAT anything.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Yep.  Removed NAT statements and it worked.  Thx much
