Cisco 2911 Dual ISP route
ThomasMull9000
Hello Guys
We have a cisco 2911 cisco router so i want to use as a load balancer using two different ISP networks, example if the first ISP network gets down i need the second ISP will take over all routing and get for internet access
here is my scenerio..
First ISP = PUblic ip =    155.1555.155.2  gateway =   155.155.155.1
seceond ISP Public =    40.51.16.9           gateway =    40.51.16.1
Inside network = 192.168.1.0. /24
5 Replies 5
cadet alain
You can try this:
ip sla 1
icmp-echo 8.8.8.8
timeout 1000
frequency 3
ip sla schedule 1 start-time now life forever
track 1 ip sla 1
ip route 0.0.0.0 0.0.0.0 155.155.155.1  track 1
ip route 0.0.0.0 0.0.0.0 40.51.16.1 10
access-list 110 permit icmp host 8.8.8.8
route-map SLA_TRACK permit 10
match ip address 110
set ip next-hop 155.155.155.1
exit
ip local-policy route-map SLA_TRACK
On inside interface: ip nat inside
On Outside interface: ip nat outside
access-list 10 permit 192.168.1.0 0.0.0.255
route-map PRIMARY permit 10
match ip address 10
match ip next-hop 155.155.155.1
route-map BACKUP permit 10
match ip address 10
match ip next-hop 40.51.16.1
exit
ip nat inside source route-map PRIMARY interface x/x   where x/x is going to 155.155.155.1
ip nat inside source route-map BACKUP interface x/x   where x/x is going to 40.51.16.1
Regards.
Alain
Hi, I have a question to that set-up,
with 2 or more lines set up as load ballancing, can you add vpn s2s with load ballancing also?
s2s IPSec is an overlay of your load-balancing.  If your load-balancing works, s2s IPSec will work as well, as long as you use a loopback interface for your crypto map (i.e. crypto map local-address lo0) so that your IPSec is independent of the ISP and it will utilize both ISP
do you have any example off hand?
on cisco 2911:
ip access-list extended vpn
  permit ip your_lan/x  remote_lan_x
crypto isakmp key cciesec address vpn_peer_x no-xauth
interface lo0
ip address 4.2.2.2 255.255.255.255 (make sure that this loopback address is reachable on the Internet)
crypto isakmp pol 1
  authen pre-sh
  hash sha
  ecnr aes 256
  group 5
  life 86400
no crypto ipsec udp-en (not sure about the exact syntax)
crypto ipsec trans tset esp-aes 256 esp-sha-hmac
crypto map local-address looback0
crypto map vpn 10 ipsec-isakmp
  set peer vpn_peer_x
  set transform tset
  set pfs group5
  set securify life sec 3600
  mat address vpn
interface lo0
  crypto map vpn
interface g0/0
  ip address ISP1
  crypto map vpn
interface g0/1
  ip address ISP2
  crypto map vpn
