Cisco 2911 ISP Duwal WAN seperate VLAN NAT Configuration
I have a Cisco 2911 ISR that has two separate WAN ports each used by a different VLAN behind the router.
Gi0/1 is statically connected to the first ISP via Dialer1.  This network host all of our business IP traffic, including access to the Internet,  Very shortly  it will be used for Static-Dynamic IPSEC VPN ( This has not been configured yet)
Gi0/2 is a dynamically provided ISP connection that is meant for users on VLAN2 for personnel not business related network/internet access.  FE0/0/0-8 are used to connect to the Cisco 3560 switch and to all the POE AP's we have on our facility.  the AP's all have two SSID's assigned one SSID is for VLAN1 and one for VLAN2.
I currently have Internet connectivity thru VLAN1, I do not have internet connectivity thru VLAN2, I am able to ping the router that Gi0/2 in connected to using ping 192.168.1.1 (router address for network that Gi0/2 is connected) source VLAN2
I think I have an issue with my NAT policy?  However I am not experienced enough to find it or make the right changes.
Running Config.
Current configuration : 4594 bytes
! No configuration change since last restart
version 15.2
hostname Router
boot-start-marker
boot-end-marker
enable secret 4 XXXXX
no aaa new-model
clock timezone PST -8 0
clock summer-time PST date Mar 10 2019 0:00 Nov 3 2019 0:00
clock calendar-valid
ip cef
ip dhcp excluded-address 192.168.10.1 192.168.10.60
ip dhcp excluded-address 192.168.20.1 192.168.20.60
ip dhcp pool VLAN2
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 208.67.220.220 208.67.222.222
ip dhcp pool VLAN1
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
no ip domain lookup
ip multicast-routing
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1620AH5A
license boot module c2900 technology-package securityk9
hw-module sm 1
vtp domain XXXXXX
vtp mode transparent
redundancy
vlan 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description BusinessUse
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 10
interface GigabitEthernet0/2
description PersonnelUse
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no routing dynamic
interface FastEthernet0/1/0
switchport trunk allowed vlan 1-3,1002-1005
switchport mode trunk
no ip address
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
description Netgear AP Kitchen
switchport trunk allowed vlan 1,3,1002-1005
no ip address
interface FastEthernet0/1/3
description Cisco AP Service Bay
no ip address
interface FastEthernet0/1/4
description Cisco AP Data Room
no ip address
interface FastEthernet0/1/5
description Cisco AP FCR
no ip address
interface FastEthernet0/1/6
description Cisco AP Dayroom
no ip address
interface FastEthernet0/1/7
description Cisco AP Gym
no ip address
interface FastEthernet0/1/8
description Access VLAN2 only!!
switchport access vlan 2
no ip address
interface FastEthernet0/2/0
no ip address
interface FastEthernet0/2/1
no ip address
interface FastEthernet0/2/2
no ip address
interface FastEthernet0/2/3
no ip address
interface GigabitEthernet1/0
no ip address
shutdown
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip policy route-map PBR
interface Vlan2
ip address 192.168.20.1 255.255.255.0
ip helper-address 192.168.1.1
ip nat inside
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 10
ppp authentication chap callin
ppp chap hostname XXXXXXXXX
ppp chap password 0 XXXXXXXX
ppp ipcp route default
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
ip nat inside source list 20 interface GigabitEthernet0/2 overload
ip access-list extended VLAN1
permit ip 192.168.10.0 0.0.0.255 any
ip access-list extended VLAN2
permit ip 192.168.20.0 0.0.0.255 any
kron occurrence reload-daily at 2:00 recurring
policy-list reload-daily
kron policy-list reload-daily
cli reload
access-list 10 permit 192.168.10.0 0.0.0.255
access-list 20 permit 192.168.20.0 0.0.0.255
route-map PBR permit 10
match ip address VLAN1
set ip next-hop verify-availability
route-map PBR permit 20
match ip address VLAN2
set ip next-hop 192.168.1.1
control-plane
line con 0
exec-timeout 30 0
password XXXXXXX
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
flowcontrol software
line vty 0 4
privilege level 15
password XXXXX
login
transport input telnet ssh
transport output telnet ssh
scheduler allocate 20000 1000
end
the route map doesn't look right. Change it to:
set ip next-hop 192.168.10.1
set ip next-hop 192.168.20.1
Cristian Matei
   Use the following route-map config, instead of what you have:
set interface Dialer1
set interface GigabitEthernet0/2
set ip next-hop dynamic dhcp
Cristian Matei.
