Cisco 2911 l2tp throughput
timur.huseynov
Hello.
I've configured l2tpv3 between 2 Cisco 2911 over WAN. Everything is working. Although all links and ports are GigabitEthernet throughput between these 2 routers are 80 mbits (non encrypted traffic). I've also statically configured all interfaces to 1 gbit speed and checked all scheme with directly connected 2 routers. But nothing changes. What could be a problem? There is no any documentation about maximum throughput for l2tp on Cisco 2911
P.S. All patch cords I used are Cat6 category.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What's your CPU stats look like when you're at 80 Mbps?
Cisco recommends a 2911 for up to 35 Mbps of WAN bandwidth.  The router's performace varies, and is often can do more than 35 Mbps (as your 80 Mbps demostrates) but (especially) on ISRs, gig interfaces do not often mean gig performance.
Joseph W. Doherty
Disclaimer
Posting
