Cisco 2911 license
I have a 2911 router. I want to apply IP SLA command but there is none.
My router version as below:
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
Do i need to purchase license?
Just looked it up in the feature-navigator. It seems that you need a SEC, DATA or UC license and that IP BASE is not enough.
I see, i thought need to update firmware?
because usually if 1800 or 2811 if their is no command usually need to update firmware.
i did search, do i need this one
( L-SL-29-APP-K9= ) AppX License with; DATA and WAAS for Cisco 2900 Series
i wonder, how to apply the license to existing router?
APP is one of the possible licenses. Perhaps SEC gives you more possibilities to use the router? Or just compare the prices.
Here is a document on activating feature licenses:
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html
