Cisco 2911 lost routing command
Matteo Abrile
today I found 2 our routers without routing command, "ip route" and "router eigrp" are delete from running-config, meanwhile they are inside startup-config, when I try add again them, routers tell me i can't because disable routing, so I add "ip routing", after this command I can add again configs that routers loose, but I need reload it to come work 100%.... routing works meanwhile dmvpn not works, mgre tunnels not come up.
After add loose lines and reboot, router come work fine.
Have you some idea about what can do ? I fix problem but I would know why ? to solve problem.
inside logging... I can't found any.
M.
Hello
It sounds like Ip routing was disabled thus delelting the eigrp process.
Are you saying after you renabled ip routing and added back all the routing configuration and rebooted the route connectivity was restored?
If so what are you asking?
res
Paul
Kind Regards
Paul
I know problem is disable ip routing, i ask why it disabled... itself...
M.
sh runn
sh star
sh ver
and do u have syslog server? to see what happened
if dont so install it
today I apply ACL on spoke router to receive traffic only from hub and viceversa.
Now I will see if problem occur again. I think maybe attack using bug, because during today I have it on every my router.
M.
