COMMAND TO VIEW/CHANGE NETWORK PASSWORD
buzzhani1
Is there a command, which one can use to view the current wifi password for a wireless network from a cisco router. e.g a 1900 series router..?
EDIT
Also what is the command to CHANGE a wireless network password from a router such as cisco 1900 series?
Thanks.
6 Replies 6
Leo Laohoo
No, none.
okay thanks.
I know for low-end routers like linksys E3000 for example, the wifi password is changed from the web GUI. What's the process for commercial routers like 1900 or 2900 series routers? OR Does it have to be done via the modem..?
No (legitimate) device will show you what the password is.  It is OK to CHANGE the password but there is no way to view the password.
oh okay.. i was actually asking (in the previous post) about the procedure to change the password for a network using a commercial router? For home routers it's done via their GUI, how is it done with this high-end routers?
its command line, and depending on the size of the network, usually scripted.
Any ideas on this?
