Cisco 2911 Router unable to boot up
Sreejesh S
     I was faced password issue after trying to recover my router password my router is not booting up to normal mode now its only show ROMMON1> mode how will rectify this.  I was tried to restart and even tried to change CONF value but not working
how can solve this
Sreejesh S
Richard Strnad
Level 4
Level 4
Hi Sreejesh,
Enter:
boot
And post the output here if its not working.
Richard
Richard Strnad
Level 4
Level 4
Hi Sreejesh,
Enter:
boot
Richard
Vignesh Rajendran Praveen
Hi Sreejesh,
Try the below.
Step1 -
rommon>dev
Step 2 - next choose the valid storage location & execute below
rommon> dir
step 3 - execute below
rommon>boot :
Kindly follow the above steps & check if it helps.  Also kindly see to it that the confreg value is set 0x2102
Hope this helps.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
