Cisco 2911 with Switch module and multicast
nasus32163
I have a Cisco2911 with a 16 port switch module.  I want to pass multicast from ports on the switch through the router to outside networks.
What ios and configuration do i need to allow this to happen?  I can pass multicast on the switch itself between clients - I just can't get it to pass to the router.  Do I have to put a physical connection from the gig ports?
Thank you
Edison Ortiz
If the outside network is not part of the same subnet as your 16 port switch module, you need to configure multicast routing.
You need to configure PIM Sparse Mode under your Layer3 interfaces, enable multicast-routing globally and select one router as your Rendezvous Point.
Can you provide a network topology diagram?
Thank you.  I am mobile this weekend but expect to be back in the office and can email more effectively.  do you have a sample router config in the meantime?    I currently have the C2900-universalk9-mz.SPA.150-1.M6 ios with the ip base and uc technology package license on the router, but am not sure what i have on the switch until I return.  Will either affect my efforts?
Thank you.
Susan
