Sample Config - 2911 router and SM-ES2-16-P
Scott H
Can someone post a sample config for a similiar router and switch module configuration? I am really interested in the router int ports addressing in relation to switch module and the proper configuration.
Pulkit Nagpal
Hi Scott,
Please use following links for reference:
this is software configuration guide for 2900 series router:
http://www.cisco.com/en/US/docs/routers/access/1900/software/configuration/guide/Software_Configuration.html
Here are a few discussion from CSC, they have sample configurations:
https://supportforums.cisco.com/thread/2038296
https://supportforums.cisco.com/message/3151348#3151348
Further, i would suggest you search at CSC for similar configurations, you will find lots.
Please mark this post as answered if you think you got answer to your question,  as that will help othes use this as well.
Pulkit
Pulkit Nagpal
Hello Scott,
If you find the information provided helpful, please mark this post as answered so that others can benefit from this as well.
Pulkit
