Cisco 2921 Modules
fgasimzade
Level 4
Level 4
Helloe everyone!
Got a question regarding 2921 modules. Can I use VWIC2-2MFT-T1/E1 along with NM-HDV2-2T1/E1 on 2921 and what is the minimum requirements for IOS image?
As I understand, NM-HDV2-2T1/E1 is supported on 2921, however VWIC2-2MFT-T1/E1 is not,  VWIC-2MFT-T1/E1 only. But VWIC-2MFT-T1/E1
is not supported on 2921. Got stuck here.. Please advice
Reza Sharifi
According to the data sheet you are correct.  Only NM-HDV2-2T1/E1 is supported on 2900 series.
You also need IOS 15 to support it.
Have a look at the data sheet.
http://www.cisco.com/en/US/products/ps10537/products_relevant_interfaces_and_modules.html
Reza
Reza Sharifi
Reza
Thank you Reza.
What about VWIC2-2MFT-T1/E1?
Oh, it is supported, thank you
Looking at the link I provided, it says it is supported, but when you click on the link to look at the detail, there in no 2900 series support at all.
Here it is:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
