Cisco 2951 Error
ioan_ploscariu
I have a cisco router 2951 and this is the message that apear on the console:
ERROR: DDR  controller 1 data training time out during initialization! Stop.
What does  it mean?
Thanks.
Amit Aneja
Level 3
Level 3
Does the device keep rebooting printing this log?
Have you tried booting this router without the modules plugged in?
If this is rebooting with this message, this indicates hardware failure.
HTH,
Amit
jaehun jeon
Could you write err message?
I think that err is about platform in board or memory part.
And you see the message again after rebooting device.
May this router is fault about platform.
Jeon
hi,
the term "controller 1" is representing hardware interface module on your router.
Try the suggestion by amit. remove all interface modules and reboot ur router.
If not a hardware failure, then it may be a IOS bug.
Try to put your router in ROMMON mode and try to upload ios.
