Cisco 2951 router issues
roncro
Level 3
Level 3
Hello,   I have a Cisco 2951 router I use at home,  and I suspect it to give me some issues.
The internet (via a cisco cable modem)  drops the conenction (status says there is no traffic)  and the connection drops
I checked the router and I see log messages saying:
Oct 12 01:09:41.068: %IP_VFR-3-COALESCE_ERROR: Unable to coalesce fragments arriving through GigabitEthernet0/0 - datagram 4121 bytes is too big. UDP packet 75.75.75.75:53 -> A.B.C.D:59499 has ident: 50999 flags:0x0 and 3 fragments
At first I thought it was the modem, or the cable connection,  but now I am not sure.  The problem seems to be intermittent and comes in "waves".
(The 75.75.75.75 is a comcast dns server)
Also,  when the  internet connection drops,  the router seems to become unresponsive (can't ping it,  if logged it it drops the session)
any ideas?
Ron
22 Replies 22
I tried following the instructions.
The router/2951 doesn't know
sh bootvar
(it doesn't recognize
bootvar
)   can I just skip it and proceed from the conf t(erminal) on?  (also, flash doesn't exist,  but flash0:  (dir flash doesn't work,  dir flash0  does)
thanks,
Ron
Hello Paul,
the
show bootvar
the 2951 doesn't seen to recognize
bootvar
Could I just skip it?  and continue ?   Also   I think it doesn't recognize 'flash'  it's called flash0 on mine  (dir flash doesn't work,  dir flash0 does work.
Also with the
boot system
calls,  why do I need to use both the new and the old one in the call?
boot system flash:xxxnNEWxx.bin
boot system flash:xxxnOLDxx.bin  ?
Shouldn't I just use the new one?
thanks!
Ron
roncro
Level 3
Level 3
Also, the newest one doesn't look like it will fit,  not enough room?
this is what is on there:
1 -rw- 66547544 May 28 2012 04:30:02 -06:00 c2951-universalk9-mz.SPA.151-4.M4.bin
2 -rw- 2814 May 28 2012 04:37:14 -06:00 cpconfig-29xx.cfg
3 -rw- 3000320 May 28 2012 04:37:28 -06:00 cpexpress.tar
4 -rw- 1038 May 28 2012 04:37:36 -06:00 home.shtml
5 -rw- 122880 May 28 2012 04:37:46 -06:00 home.tar
6 -rw- 1697952 May 28 2012 04:37:58 -06:00 securedesktop-ios-3.1.1.45-k9.pkg
7 -rw- 415956 May 28 2012 04:38:08 -06:00 sslclient-win-1.1.4.176.pkg
8 -rw- 1142 Jul 24 2012 07:07:52 -06:00 FCZ1622702R_20120724014232364.lic
9 -rw- 97911952 Oct 28 2015 06:44:34 -06:00 c2951-universalk9-mz.SPA.154-1.T1.bin
show version  shows me the running version:
System image file is "flash0:c2951-universalk9-mz.SPA.151-4.M4.bin"
so there are things I don't need (I think), looks like I don't need
cpexpress.tar, home.tar (and do I need securedeskop-ios or sslclient-win
and there's a c2951-universalk9-mz that's newer then what's running?
thanks,
Ron
roncro
Level 3
Level 3
btw:   trying to back stuff up on the tftp server, but get some weird errors.
Charon-2951#copy flash0:c2951-universalk9-mz.SPA.154-1.T1.bin tftp
Address or name of remote host []? 192.168.2.8
Destination filename [c2951-universalk9-mz.SPA.154-1.T1.bin]?
%Error opening tftp://192.168.2.8/c2951-universalk9-mz.SPA.154-1.T1.bin (No such file or directory)
I guess I am doing something wrong
Ron
roncro
Level 3
Level 3
Update:
I adapted the commands, with wat I saw on my router,  that seemed to work.  So I have the newerish IOS running now.  (I am wondering still,  if I can save the old image to my ftp server to save it?)  Just in case.
If I delete the oldest IOS,  and put the new one
(c2951-universalk9-mz.SPA.156-3.M9.bin)
on it I'd have 4Mb left or so, is that a good idea?
thanks,
Ron
Hello
Yes, if you have the new ios on now and you dont have much space remove the old one, also the cpexpress tar  file if you dont use it?.
delete flash0:c2951-universalk9-mz.SPA.151-4.M4.bin
delete flash0:cpexpress.tar
copy flash0:c2951-universalk9-mz.SPA.154-1.T1.bin tftp: <--colon
Kind Regards
Paul
Hi Paul,
cool,  I'll do that.
The
still gives me the same error
%Error opening tftp://192.168.2.8/IOS/c2951-universalk9-mz.SPA.154-1.T1.bin
And of course it isn't there,  because I want to move it from the router,  to the ftp server , as a backup.
Is it possible to copy a single file from the router to  an tftp server?
(I'd rather back it up before I delete it)
thansk,
Ron
Ron
roncro
Level 3
Level 3
I think I got it;
Charon-2951 uptime is 8 minutes
System returned to ROM by reload at 20:10:37 MDT Fri Oct 13 2023
System restarted at 20:13:13 MDT Fri Oct 13 2023
System image file is "flash0:c2951-universalk9-mz.SPA.156-3.M9.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Charon-2951#dir
Directory of flash0:/
1 -rw- 115438536 Oct 13 2023 20:05:16 -06:00 c2951-universalk9-mz.SPA.156-3.M9.bin
3 -rw- 1038 May 28 2012 04:37:36 -06:00 home.shtml
4 -rw- 122880 May 28 2012 04:37:46 -06:00 home.tar
5 -rw- 1697952 May 28 2012 04:37:58 -06:00 securedesktop-ios-3.1.1.45-k9.pkg
6 -rw- 415956 May 28 2012 04:38:08 -06:00 sslclient-win-1.1.4.176.pkg
7 -rw- 1142 Jul 24 2012 07:07:52 -06:00 FCZ1622702R_20120724014232364.lic
8 -rw- 97911952 Oct 28 2015 06:44:34 -06:00 c2951-universalk9-mz.SPA.154-1.T1.bin
256507904 bytes total (40898560 bytes free)
looks right,  doesn't t?
I hope it solves my problem,  with that coalescent/rom error.
Ron
PS;  the tftp error was a  configuration error on the tftp server,  it only allowed reading,  the -c option (allow it to create files) solved that part.
