10-11-2023
06:23 PM
- last edited on
10-26-2023
12:02 AM
by
Translator
Hello, I have a Cisco 2951 router I use at home, and I suspect it to give me some issues.
The internet (via a cisco cable modem) drops the conenction (status says there is no traffic) and the connection drops
I checked the router and I see log messages saying:
Oct 12 01:09:41.068: %IP_VFR-3-COALESCE_ERROR: Unable to coalesce fragments arriving through GigabitEthernet0/0 - datagram 4121 bytes is too big. UDP packet 75.75.75.75:53 -> A.B.C.D:59499 has ident: 50999 flags:0x0 and 3 fragments
At first I thought it was the modem, or the cable connection, but now I am not sure. The problem seems to be intermittent and comes in "waves".
(The 75.75.75.75 is a comcast dns server)
Also, when the internet connection drops, the router seems to become unresponsive (can't ping it, if logged it it drops the session)
any ideas?
Ron
Solved! Go to Solution.
10-13-2023
05:57 PM
- last edited on
10-29-2023
09:10 AM
by
Translator
Hello
@roncro wrote:
If I delete the oldest IOS, and put the new one
(c2951-universalk9-mz.SPA.156-3.M9.bin)on it I'd have 4Mb left or so, is that a good idea?
Yes, if you have the new ios on now and you dont have much space remove the old one, also the cpexpress tar file if you dont use it?.
delete flash0:c2951-universalk9-mz.SPA.151-4.M4.bin
delete flash0:cpexpress.tar
@roncro wrote:(No such file or directory)
%Error opening tftp://192.168.2.8/c2951-universalk9-mz.SPA.154-1.T1.bin
I guess I am doing something wrong
copy flash0:c2951-universalk9-mz.SPA.154-1.T1.bin tftp: <--colon
10-11-2023
07:03 PM
- last edited on
10-26-2023
02:40 AM
by
Translator
Also once the connection is up, when I ping google.com the
icmp
responses I get come from youtube-ui.l.google.com .. and when I do a traceroute to something (like a dns server) I seeem to get different routes, with different response times
10-12-2023 04:44 AM
I found some references to bugs that could generate this error. Is the router directly on the internet with a public IP address? If so, it could be getting attacked. If it is behind a firewall then the bug scenario sounds more likely.
10-12-2023 08:54 AM
Yes it is connected to the internet via a modem, but from the outside only an ssh port is open, and is directly forwarded to a linux machine. (which has a firewall)
10-12-2023
05:06 AM
- last edited on
10-26-2023
02:43 AM
by
Translator
Can you post show version and show interface
GigabitEthernet0/0
10-12-2023
09:00 AM
- last edited on
10-26-2023
02:44 AM
by
Translator
Here it is,
it looks like it just restarted ...
here is the info, thanks!
Charon-2951 uptime is 16 minutes
System returned to ROM by address error at PC 0x4AC7AD4, address 0x4AC7AD4 at 09:36:57 MDT Thu Oct 12 2023
System restarted at 09:38:53 MDT Thu Oct 12 2023
System image file is "flash0:c2951-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 483328K/40960K bytes of memory.
Processor board ID FCZ1622702R
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2951/K9 FCZ1622702R
Technology Package License Information for Module:'c2951'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
Charon-2951#show interface GigabitEthernet0/0
GigabitEthernet0/0 is up, line protocol is up
Hardware is PQ3_TSEC, address is a44c.11d4.afc0 (bia a44c.11d4.afc0)
Description: WAN
Internet address is 69.254.c.d/23
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/185/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1371000 bits/sec, 158 packets/sec
5 minute output rate 72000 bits/sec, 56 packets/sec
464814 packets input, 458030740 bytes, 0 no buffer
Received 5 broadcasts (0 IP multicasts)
0 runts, 0 giants, 3 throttles
0 watchdog, 0 multicast, 0 pause input
189244 packets output, 26921538 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
10-12-2023 10:27 AM
Hello
Possible bug <here> try upgrading software.
10-12-2023
10:42 AM
- last edited on
10-27-2023
05:02 AM
by
Translator
Thanks Paul,
I checked and saw, this below. Is there an "ideal" size to try? (without messing too much up?)
(I did actually see some " Unable to coalesce fragments.." errors yesterday, but don't see them now any more. They appeared to be generated by a
comcast/xfinity dns server
thanks,
Ron
Charon-2951(config)#buffers huge size ?
<18024-65535> Size of huge buffers
Charon-2951#show buffers
Buffer elements:
592 in free list (500 max allowed)
55988 hits, 0 misses, 617 created
Public buffer pools:
Small buffers, 104 bytes (total 80, permanent 50, peak 80 @ 00:28:35):
77 in free list (20 min, 150 max allowed)
18326 hits, 10 misses, 0 trims, 30 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 58, permanent 25, peak 58 @ 00:28:35):
56 in free list (10 min, 150 max allowed)
10816 hits, 11 misses, 0 trims, 33 created
Big buffers, 1536 bytes (total 51, permanent 50, peak 51 @ 00:29:22):
51 in free list (5 min, 150 max allowed)
27026 hits, 0 misses, 0 trims, 1 created
VeryBig buffers, 4520 bytes (total 11, permanent 10, peak 11 @ 00:29:22):
11 in free list (0 min, 100 max allowed)
8098 hits, 0 misses, 0 trims, 1 created
Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 00:29:36):
1 in free list (0 min, 10 max allowed)
0 hits, 0 misses, 0 trims, 1 created
Huge buffers, 18024 bytes (total 5, permanent 0, peak 5 @ 00:29:22):
5 in free list (4 min, 10 max allowed)
0 hits, 0 misses, 0 trims, 5 created
10-13-2023
11:16 AM
- last edited on
10-27-2023
05:00 AM
by
Translator
Hello Paul,
Upgrading the software, that means downloading a newer version of
"System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)" or of "flash0:c2951-universalk9-mz.SPA.151-4.M4.bin"
(does one need a subscription for that?)
thanks,
Ron
10-13-2023 11:21 AM
If you like to download the software if your account CCO entitled then you can download
you need to download only IOS Image, Until the release notes ask you to upgrade ROMMON you do not need to upgrade that.
You can download 15.6 or 15.7 if you are entitled to download.
10-13-2023 11:25 AM
Hello BB,
I don't have a service contract for that router, so it looks like I can't download the updates.
thanks,
Ron
10-13-2023 12:37 PM
Hello
As long as you have a valid licence you will be okay
10-13-2023
12:41 PM
- last edited on
10-27-2023
05:05 AM
by
Translator
Ok, thanks, I am trying to make room now.
Maybe I should first see if I can make
the current running image, since
is the one in use.
Then after that worked, delete
151-4-mM4
one.. and try the
156/157?
(I wonder why it is on there, maybe it's corrupted)
thanks,
Ron
10-13-2023
12:57 PM
- last edited on
10-27-2023
05:09 AM
by
Translator
Hello
Yes install the new image and set the boot variable to run it as default.
Example: xxx.bin file
Copy new ios to flash via tftp:
copy tftp:xxxxxxx.bin flash:
verify /md5 flash:xxxx.bin
dir flash:
sh bootvar
conf t
no boot system
boot system flash:xxxnNEWxx.bin
boot system flash:xxxnOLDxx.bin
exit
wr
reload
rtr should boot to new image, as/when your happy delete the old image from flash.
10-13-2023
02:25 PM
- last edited on
10-27-2023
05:15 AM
by
Translator
I am going to try that;
the one that is running now is
There is another one located on
flash: c2951-universalk9-mz.SPA.154-1.T1.bin
(but don't know the state)
and I have also
(but not on flash)
So with the above I want to switch to the
to see if it works. Then back up the
with tftp and delete it.
Thendo the same thing again with
thanks!
Ron
