Cisco 2951 - unknown Error in log
Chris9811
since two weeks i have a little problem with my Cisco 2951.
My problem is, that i get the following error from my Cisco router every 10 seconds:
*Mar 17 12:14:19.728: %SYS-2-BLOCKHUNG: Task hung with blocking disabled, value = 0x1. -Process= "Inspect process", ipl= 0, pid= 321
-Traceback= 5C39364z 4F4F3D8z 404CC10z ADCF40Cz 4F687ACz 4F4F6DCz
*Mar 17 12:16:47.700: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "Inspect process", ipl= 0, pid= 321
-Traceback= 5C39364z 4F4F39Cz 404CC10z ADCF40Cz 4F687ACz 4F4F6DCz
*Mar 17 12:16:48.700: %SYS-2-BLOCKHUNG: Task hung with blocking disabled, value = 0x1. -Process= "Inspect process", ipl= 0, pid= 321
and i dont know what this error means? I hope anyone can help me out.
5 Replies 5
Leo Laohoo
Traceback always means an IOS bug.
Ok.
Thank you very much for the fast answer!
That means i have to update my IOS?
Yes.
I have been getting a similar issue since 15.6(2)T and I have to keep reverting to 15.6(1)T2.  I get the follwing tracebacks continually:
000110: Jul 30 14:25:01.958: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "Inspect process", ipl= 0, pid= 297
-Traceback= 7048A78z 607E4C8z 404D398z 9D6CD44z 60978D8z 607E808z
000111: Jul 30 14:25:02.958: %SYS-2-BLOCKHUNG: Task hung with blocking disabled, value = 0x1. -Process= "Inspect process", ipl= 0, pid= 297
-Traceback= 7048A78z 607E504z 404D398z 9D6CD44z 60978D8z 607E808z
000115: Jul 30 14:26:02.915: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "Inspect process", ipl= 0, pid= 297
000116: Jul 30 14:26:03.915: %SYS-2-BLOCKHUNG: Task hung with blocking disabled, value = 0x1. -Process= "Inspect process", ipl= 0, pid= 297
000124: Jul 30 14:28:31.904: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "Inspect process", ipl= 0, pid= 297
000125: Jul 30 14:28:32.904: %SYS-2-BLOCKHUNG: Task hung with blocking disabled, value = 0x1. -Process= "Inspect process", ipl= 0, pid= 297
000129: Jul 30 14:29:32.825: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "Inspect process", ipl= 0, pid= 297
000130: Jul 30 14:29:33.825: %SYS-2-BLOCKHUNG: Task hung with blocking disabled, value = 0x1. -Process= "Inspect process", ipl= 0, pid= 297
It is very evident to users when SIP calls are in place as the traffic is interupted.
I noticed 15.6(1)T3 is available so I will try this and retest to see if its still in this release.  EDIT:  Installed 15.6(1)T3 and this doesn't exhibit this behaviour.  15.6(2)Tx, 15.6(3)Mx and 15.7(3)M all have this issue.
Andy
We are also facing the same issue.
Log:
                Line 86: Jul  5 08:38:15.586: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "Inspect process", ipl= 0, pid= 304
       Line 91: Jul  5 09:41:20.270: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "Inspect process", ipl= 0, pid= 304
       Line 95: Jul  5 11:34:20.749: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "Inspect process", ipl= 0, pid= 304
Even after IOS upgraded to latest stable code still issue persists.
