CISCO 2960 access switch -QOS
alison.hou
I am creating input QOS service policy to classify my business critical traffic. Can I use mls qos trust dscp to trust IP phones and service-policy QOS-LAN for my business critical traffic on the same interface?
interface FastEthernet0/1
description VOIP-NETWORK DEVICES
switchport access vlan 100
switchport mode access
switchport voice vlan 200
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust dscp
auto qos voip trust
no cdp enable
service-policy input QOS-LAN
thanks,
Alison
6 Replies 6
Peter Paluch
Hello Alison,
I am afraid you can not. According to:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/15.0_2_se/command/reference/cli2.html#wp6193114
Classification using a port trust state (for example, mls qos trust [ cos | dscp| ip-precedence ] ) and a policy map (for example, service-policy input policy-map-name) are mutually exclusive. The last one configured overwrites the previous configuration.
You will have to deal with all traffic using only one of these approaches.
Best regards,
Peter
THANKS FOR THE INPUT.
I applied service-policy  after configuring mls qos trust. But I did not see any matched packets by typing show policy-map interfaces
How do I verify that my input policy has been correctly configured and matching packets. see result here: I did see some matched packets from my router but not much.
from 2960 access switch.
FastEthernet0/2
  Service-policy input: QOS-LAN
    Class-map: BUSCRIT-INTER-1 (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name ACL-BUSCRIT-INTER-1
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: BUSCRIT-INTER-2 (match-any)
      0 packets, 0 bytes
      Match: access-group name ACL-BUSCRIT-INTER-2
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: BUSCRIT-TRANS-1 (match-any)
      0 packets, 0 bytes
      Match: access-group name ACL-BUSCRIT-TRANS-1
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: BUSCRIT-TRANS-2 (match-any)
      0 packets, 0 bytes
      Match: access-group name ACL-BUSCRIT-TRANS-2
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
Hello Alison,
The statistics in the show policy-map output are not to be trusted - the reason is that these switches are performing the operations in hardware while the counters shown in this output are based on software packet processing that does not take place on switches.
The command reference at
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/command/reference/cli2.html#wp1948343
states: Though visible in the command-line help string, the control-plane and interface keywords are not supported, and the statistics shown in the display should be ignored.
Unfortunately, I have no immediate idea how to verify that your configuration works indeed. Generally, this is a problem on platforms where the packet processing is offloaded to specialized hardware.
Best regards,
Peter
Thanks for the information. that made me feel better.
Will the show policy-map work in a router (2801 or 2911 etc)? I did see some traffic there. are the resultes correct?
Serial0/1/0
  Service-policy output: QOS-WAN
    Class-map: VOIP (match-any)
      1132010 packets, 73940855 bytes
      Match: ip dscp ef (46)
        5 minute rate 0 bps
      Queueing
        Strict Priority
        Output Queue: Conversation 264
        Bandwidth 40 (%)
        Bandwidth 614 (kbps) Burst 15350 (Bytes)
        (pkts matched/bytes matched) 17268/1149112
        (total drops/bytes drops) 0/0
    Class-map: BUSCRIT-INTER (match-any)
      104901 packets, 17929287 bytes
      Match: ip dscp af31 (26)
        104724 packets, 17888299 bytes
        5 minute rate 0 bps
      Match: ip dscp af32 (28)
        177 packets, 40988 bytes
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 265
        Bandwidth 36 (%)
        Bandwidth 552 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 2607/862982
        (depth/total drops/no-buffer drops) 0/0/0
    Class-map: BUSCRIT-TRANS (match-any)
      698338 packets, 45863498 bytes
      Match: ip dscp af21 (18)
        697992 packets, 45783119 bytes
        5 minute rate 0 bps
      Match: ip dscp af22 (20)
        346 packets, 80379 bytes
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 266
        Bandwidth 18 (%)
        Bandwidth 276 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 6171/4969583
      1634436 packets, 338482388 bytes
      5 minute offered rate 38000 bps, drop rate 0 bps
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 256
        (total queued/total drops/no-buffer drops) 0/1026/0
Alison
Hi Alison,
Yes, on software based routers such as ISR or ISR G2, the show policy-map counters are correct and you can trust them.
Best regards,
Peter
Eloy Pascal
You have to think in terms of trust regardless of IOS accepting the configuration or not. To make the point clearer, if the port is trusted (meaning for example it is an uplink Port to Distribution Switch or Next-Hop Router) then you configure "mls qos trust dscp" however if the port is untrusted (meaning for example the port connects to an end Host) then you want to mark incoming packets with an inbound policy like "service-policy input QOS-LAN". I recommend these set of commands as well whether the port is trusted or untrusted: "priority-queue out", "queue-set 1", "srr-queue bandwidth share 10 10 60 20", and "srr-queue bandwidth shape 10 0 0 0" -> The reason for these 4 commands is because Cat2960 does not provide the optimum egress queueing configuration. Specifically this occurs when one type of traffic predominates on the switch ports, usually when the switch is used to connect a server (then if you can see drops in some queues while other queues are under utilized. This is due to the way the buffer resources have been divided between the queues).
