Cisco 3200 series - remove interface card
cuongtran1
I have a Cisco 3220 and it has multiple interface cards (Ethernet and Serial). I  removed the serial interface on this router, but the router keeps rebooting. Is it possible to the remove the serial interface card on the router?
Cuong Tran
Philip D'Ath
It looks like it is removable to me.  You'll have to watch the console output to see why it says it is rebooting.
Hello Philip,
I look through the console output, but unable to decode the error messages.
Here are the error messages:
*   the following cards are missing                                   *-000113%SYS-6-LOGGERSTART: Logger process started
 *   3220SMIC                                                *0:00  crashinfo_20020301-000507ial2/0, changed state to adm
 *        * Mar 01 2002 00:02:13 +00:00  crashinfo_20020301-000213:22.391: %LINK-5-
 *   To correct the problem power down the router and install the      *x      263599  Mar 01 2002 00:02:30 +00:00  crashinfo_20020301-000230tiv
 *   missing cards in the router.                                      *nte
   11  -rwx      259038  Mar 01 2002 00:00:13 +00:00  crashinfo_2002
   12  -rwx      298156  Mar 01 2002 00:00:17 +00:00
 *   For more information, please contact your vendor                  *
%Software-forced reload
   15  -rwx      280
Unexpected exception to CPUvector 700, PC = 0x80233F64, LR = 0x80233F18 restarted --
   16
-Traceback= 80233F64 80233F18 80144EE4 801450E8 80D67F04 804337D0 80433A1C 80235
   17  -r
D5C 8023A7240  Mar 01 20
CPU Register Context:shinfo_20020301-00010
MSR = 0x00029032  CR  = 0x22002024  CTR = 0x8014C94C  XER   = 0x00000000port: h
   18  -rwx      337295  Mar 01 2002 00:01:28 +00:00  crashinfo_
R0  = 0x80233F18  R1  = 0x81FC2608  R2  = 0xFFF4FFF4  R3    = 0x81DFC28C
R12 = 0x82008022  R13 = 0x87FFFF0C  R14 = 0x804339B0  R15   = 0x00000000ged state to up
  access-profile   Apply user-profile to in
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19   = 0x00000000te  Create a temporary Access-List entry
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x81FC2628  R23   = 0x81FC27B8
router1#wr
  bfe              For manual emergency mo
R24 = 0x00000000  R25 = 0x00000001  R26 = 0x00000000  R27   = 0x00000001           Change current directory marker.
R28 = 0x22008022  R29 = 0x00000000  R30 = 0x00000000  R31   = 0x00000000 I
  clock            Manage the system clo
*Mar  1 00:00:04.543: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console don related commands.
  adjacency            Adjacent nodes
  debug
ebugging output.functions (see a
*Mar  1 00:00:03.415: %MIC-7-ADD_SERIAL_NUM: Added serial number in position 0te           Delete a fileShow alignment information
  dir
*Mar  1 00:00:03.415: %MIC-7-AUTHENTICATE_PASS: Device ID #16 authenticatedCPU R          Turn off privileged commands
egister Context:t       Disconne
DEC = 0x7FFFE6F9  TBU = 0x00000000  TBL = 0x05CBAB71  PVR = 0x80811014
DAR = 0x00000000  DSISR = 0x000000þ
*** System received a Software forced crash ***
signal= 0x17, code= 0x700, context= 0x81dc0698
PC = 0x80233f64, Vector = 0x700, SP = 0x81fc2608
System Bootstrap, Version 12.3(2r)XA, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Cuong
It is very unhappy!
Try removing the config for the serial interfaces first, and then remove the card.
That software is also pretty old.  If you have access you could try a newer version of the code.
