CISCO 3560X switch software image
alison.hou
      I have a new cisco 3560x switch with  15.0.2 SE and need to be installed on the network. Should I upgraded to 15.0.2 SE4, latest release?
thanks,
Alison
14 Replies 14
brett.harding
Hi Alison,
Yes, it would be advisable to upgrade the software to 15.0.2-SE4(ED) prior to installation as the current release
15.0.2-SE(ED) is affected by a software advisory.
Cheers
Brett
Thank you for the imput, Brett.
I tried to tftp the file but got error messages here. It looked the file loaded but then it could not find it. it is confusing. can you please help? I also show you the currect image file I have on the switch. thanks,Alison
Loading c3560e-universalk9npe-mz.150-2.SE4.bin from 209.64.143.10 (via Vlan10):
[OK - 20234624 bytes]
examining image...
%Tar checksum error in tftp://209.64.143.10/c3560e-universalk9npe-mz.150-2.SE4.b
in
%Error opening flash:update/info (No such file or directory)
ERROR: Image is not a valid IOS image archive.
ATTPerimeter#archive download-sw /leave-old-sw tftp://209.64.143.10/c3560e-uni$
ATTPerimeter#dir
Directory of flash:/
    2  -rwx        3096   Mar 1 1993 08:13:46 +00:00  multiple-fs
    3  -rwx         616   Mar 1 1993 04:56:09 +00:00  vlan.dat
    4  -rwx        3982   Mar 1 1993 02:20:27 +00:00  config.text
    5  -rwx        1915   Mar 1 1993 02:20:27 +00:00  private-config.text
    6  drwx         512   Mar 1 1993 00:10:04 +00:00  c3560e-universalk9npe-mz.1
50-2.SE
57671680 bytes total (32592896 bytes free)
Hi Alison,
Please post "show version", "show bootvar"
Also which tftp software are you using? ftp may prove more reliable. Some tftp servers have a file size limitation.
Thanks, Bred.
I am using Solarwinds tftp server. here are the show results.
ATTPerimeter#sh ver
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9NPE-M), Version 15.0(2)SE
, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 27-Jul-12 23:45 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTW
ARE (fc1)
ATTPerimeter uptime is 3 hours, 29 minutes
System image file is "flash:/c3560e-universalk9npe-mz.150-2.SE/c3560e-universalk
9npe-mz.150-2.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560X-24 (PowerPC405) processor (revision A0) with 262144K bytes of me
mory.
Processor board ID FDO1651R01M
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:06:F6:28:4E:00
Motherboard assembly number     : 73-12554-08
Motherboard serial number       : FDO16503BLL
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3560X-24T-S
Daughterboard assembly number   : 800-32786-02
Daughterboard serial number     : FDO16501Z18
System serial number            : FDO1651R01M
Top Assembly Part Number        : 800-31331-07
Top Assembly Revision Number    : B0
Version ID                      : V04
CLEI Code Number                : COMJU00ARD
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       15.0(2)SE             C3560E-UNIVERSALK9NPE-M
Configuration register is 0xF
ATTPerimeter#                                             show bootvar
% Invalid input detected at '^' marker.
ATTPerimeter#                                             show bootvar ?
% Unrecognized command
ATTPerimeter#                                             show ?
  aaa                Show AAA values
  access-lists       List access lists
  adjacency          Adjacent nodes
  aliases            Display alias commands
  archive            Archive functions
  arp                ARP table
  authentication     Shows Auth Manager registrations or sessions
  auto               Show Automation Template
  beep               Show BEEP information
  boot               show boot attributes
  buffers            Buffer pool statistics
  cable-diagnostics  Show Cable Diagnostics Results
  call-home          Show command for call home
  capability         Capability Information
  cca                CCA information
  cdp                CDP information
  cef                CEF address family independent status
  cisp               Shows CISP information
  class-map          Show CPL Class Map
  clock              Display the system clock
  cluster            Cluster information
  cns                CNS agents
  configuration      Contents of Non-Volatile memory
ATTPerimeter#                                             show boot ?
  |  Output modifiers
BOOT path-list      : flash:/c3560e-universalk9npe-mz.150-2.SE/c3560e-universalk
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
NVRAM/Config file
      buffer size:   524288
Timeout for Config
          Download:    0 seconds
Config Download
       via DHCP:       disabled (next boot: disabled)
ATTPerimeter#
InayathUlla Sharieff
uick and Easy Answer:
3750/3600 series:-I recommend a "stable" IOS, then 12.2(55)SE7 .  This is followed by 15.0(2)SE2(If you required 802.1x support) else 12.2(55)SE7 is the best.
2900:- 15.0(2)SE2 works well with 2960/G/S even with 802.1x.
Hope this answered your query.
Inayath
*Plz rate this post if usefull and mark the thread as answered.
thank you for the input.
Here is the Caveat resoved in 15.0(2)SE4. Since we are using TACACS+,  I think it is very important that we need this issue resolved.
Do you know if this caveat exists in any previous versions or in v 15.0(2) SE2?
thanks,
Alison
Caveats Resolved in Cisco IOS Release 15.0(2)SE4
CSCug62154
When the switch is started using TACACS+ configurations, the CPU utilization increases to 100% and the VTY device does not work.
The workaround is to remove the TACACS+ configurations and restart the switch.
Alison,
The bug is fixed in following releases:
15.2(4)S3.3
15.1(1)IB273.54
15.4(0.4)S
15.3(2.19)S0.5
15.2(1.2.41)PI22
15.3(2.23)T
15.0(10.98)EMW
15.3(1)T1.1
12.2(33)SXJ5.47
15.1(1)SY1.32
15.0(2)SE4
15.2(4)M4.2
Inayath
**Plz rate all usefull posts.
To answer your question:
YEs this issue has been obeservered on the following releases:
15.1(2)SY
15.3(3)S
15.1(1)IB273.35
12.2(33)SXJ5.24
15.1(1)IB273.47
15.3(2.19)S0.4
12.2(33)SXJ5.44
Inayath
brett.harding
Hi Alison,
I can see two issues here. Firstly, the 15.0.2-SE4(ED) image requires 64MB of free flash space and you only have 32MB of free flash space available. This means you will not be able to store both the old and new software images. You will either need to delete the old image or upgrade the flash so that you can store both images. Secondly, it appears that you are attempting to use the archive command to install a binary image (.bin). You need to download the IOS version that includes the web based device manager (.tar). The filename should be "c3560e-universalk9npe-tar.150-2.SE4.tar"
Check the following URL for details on how to delete the old image and install the new image:
http://www.cisco.com/en/US/customer/products/hw/switches/ps646/products_configuration_example09186a0080169623.shtml#concept10
Hope that helps.
Rgds
Brett
what command do you use if you down load .bin file?
Hi Alison,
The procedure to use the .bin file is discussed in the same document I linked previously. There is a section called "
Step-by-Step Procedure for the 3550 with Use of Only the Cisco IOS Image (.bin File)". You will need to use the "copy tftp: flash:" command instead of the "archive" command. You will also need to update the boot variable with the location of the new image. Please read that section and post if you have any issues.
Rgds
Brett
alison.hou
thank you everyone for the inputs. I successfully upgraded the images.
Alison,
Good to hear that the ios have been upgraded. Could you please mark this thread as answerd and rate all usefull posts.
I was looking for the button to mark it answerd and could not find it.  all replys here are very useful. and again did not where to rate them.
thanks to all.
