Cisco 3560X_UNIVERSALK9_commands
s k
I am trying to find why the below commands doesn't show up when working on my Cisco 3560X-48, please suggest me alternatives
sh ip bgp nei
sh ip eigrp int
sh ip eigrp nei
sh ip eigrp topology
sh ip route
sh ip route summary
sh ip vrf brief
SW version - C3560E-UNIVERSALK9-M
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
>sh ver
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE1, RELEASE SOFTWARE (fc1)
2 Accepted Solutions
Julio E. Moisa
You have a license: Lanbase, with this license the IOS does not support routing and theirs commands. Lanbase is basically for layer 2 protocols.
You need an IP Base or IP service license to execute routing.  IP services licence supports a lot of protocols.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
You are welcome   :-)
The following links could be useful, your switch 3560X should be able to upgrade to ip services.
http://ciscorouterswitch.over-blog.com/2015/08/licensing-on-cisco-2960-3560-3750-series.html
http://lostintransit.se/2010/08/19/upgrading-the-license-on-a-cisco-35603750/
I order to create back up the config and current IOS you can use a tftp
https://www.pluralsight.com/blog/tutorials/how-to-back-up-and-restore-configuration-on-cisco-devices
or You can use putty in order to get a backup of the config:
Please see the attachment. Once you have created the file, you can execute show run and everything displayed on the screen will be saved on the file.
5 Replies 5
Julio E. Moisa
Hope it is useful
Thanks a lot for the reply Julio, yes that helped me understand better :-)
Are they any alternative commands that I can use in this situation? I want to upgrade this 3560X to the ip service image. Also, what should I check to see if my hardware is compatible for new ip service image upgrade?
Any command suggestions? I want to back up everything before I perform the upgrade. Thanks in advance
You are welcome   :-)
Thanks again, this really helps and appreciate your time for answering :-)
It was a pleasure my friend,
Any additional assistance please keep me posted to help you
Have a great day
