Cisco 3620 and ADSL WIC
I have a Cisco 3620 Router which has a NM-1FE2W module and that a ADSL WIC in.
I have 8Mb of flash so can't fit any of the larger IOS images on, which image should I use which supports the ADSL WIC and fits on 8Mb of flash?
Installing a larger PCMCIA card is an option but something which I may have to do if I can't do the above first.
Gareth
Juan Perez
Gareth,
What IOS version is the one you are currently running? The WIC card, is it WIC-1ADSL?
Regards.
Leo Laohoo
Cisco DSL Router Configuration and Troubleshooting Guide - ADSL WIC
Cisco IOS Software Releases 12.1(5)YB and 12.2(4)T for the Cisco 3600. Use the software feature sets that contain the PLUS feature.
Thanks for the replies Juan Perez and Leolaohoo.
I've got access to a few IOS's, when I bought the router it did have an IOS on which supported the ADSL Wic Card....but numpty here erased the flash before backing up the contents!
The trouble I'm having is finding an IOS file which is the correct PLUS feature pack and being under 8Mb!
GE
Hi Gareth,
Unfortunately "PLUS" IOS's requires a minimum of 16M of flash for this platform.
Regards.
