Cisco 3640
Lavanholy
Hi I want to replace the DRAM for Cisco 3640,Since it is EoL,and EoS,What is teh suitable DRAM I can purchase.
Thanks and Regards,
S.Venkataraman.
Danilo Dy
Though 3640 is EOS/EOL, you can still purchase DRAM replacement/upgrade for it.
Check the following links;
http://www.cisco.com/en/US/products/hw/routers/ps274/products_installation_and_configuration_guide09186a008007ce07.html'
http://www.cisco.com/en/US/products/hw/routers/ps274/prod_bulletin09186a0080091f70.html
The size and product number is in the links above. 3640 support up to a total of 128MB DRAM which is MEM3640-32U128D
Thanks for the info.
S.Venkataraman.
