CISCO 3650
pastortscog1
I have a CISCO 3650 Switch with static IP address on VLAN7 -  207.32.40.45.  I have a wireless access point configure using a private IP address of 192.168.71.148, 255.255.255.0. The wireless access point is connect on port 3. How do I get the static traffic to reach the private and vice versa?
6 Replies 6
balaji.bandi
where is this SVI for this subnet (192.168.71.X) - if the VLAN SVI in the same device it should be able to reach each other.
hopefully you have routing enabled in the device.
or post the configuration of 3650 to have a look and suggest.
BB
Current configuration : 16227 bytes
! Last configuration change at 10:01:00 CST Wed Nov 28 2018
! NVRAM config last updated at 08:56:11 CST Wed Nov 28 2018
version 15.2
no service pad
service tcp-keepalives-in
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service compress-config
service sequence-numbers
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
clock timezone CST -6 0
clock summer-time CDT recurring
switch 1 provision ws-c3650-48ps
ip routing
no ip gratuitous-arps
ip domain-name hidden
ip name-server 207.32.41.4
ip name-server 207.32.41.5
login on-failure log
login on-success log
qos queue-softmax-multiplier 100
vtp domain cisco
vtp mode transparent
authentication mac-move permit
table-map AutoQos-4.0-Trust-Cos-Table
 default copy
spanning-tree mode pvst
spanning-tree vlan 1 priority 24576
hw-switch switch 1 logging onboard message level 3
redundancy
 mode sso
ip tcp synwait-time 10
class-map match-any AutoQos-4.0-Output-Multimedia-Conf-Queue
 match dscp af41  af42  af43
 match cos  4
class-map match-any AutoQos-4.0-Output-Bulk-Data-Queue
 match dscp af11  af12  af13
 match cos  1
class-map match-any AutoQos-4.0-Output-Priority-Queue
 match dscp cs4  cs5  ef
 match cos  5
class-map match-any AutoQos-4.0-Output-Multimedia-Strm-Queue
 match dscp af31  af32  af33
class-map match-any non-client-nrt-class
class-map match-any AutoQos-4.0-Output-Trans-Data-Queue
 match dscp af21  af22  af23
 match cos  2
class-map match-any AutoQos-4.0-Output-Scavenger-Queue
 match dscp cs1
class-map match-any AutoQos-4.0-Output-Control-Mgmt-Queue
 match dscp cs2  cs3  cs6  cs7
 match cos  3
policy-map AutoQos-4.0-Output-Policy
 class AutoQos-4.0-Output-Priority-Queue
  priority level 1 percent 30
 class AutoQos-4.0-Output-Control-Mgmt-Queue
  bandwidth remaining percent 10
  queue-limit dscp cs2 percent 80
  queue-limit dscp cs3 percent 90
  queue-limit dscp cs6 percent 100
  queue-limit dscp cs7 percent 100
  queue-buffers ratio 10
 class AutoQos-4.0-Output-Multimedia-Conf-Queue
 class AutoQos-4.0-Output-Trans-Data-Queue
 class AutoQos-4.0-Output-Bulk-Data-Queue
  bandwidth remaining percent 4
 class AutoQos-4.0-Output-Scavenger-Queue
 class AutoQos-4.0-Output-Multimedia-Strm-Queue
 class class-default
  bandwidth remaining percent 25
  queue-buffers ratio 25
policy-map AutoQos-4.0-Trust-Cos-Input-Policy
 class class-default
  set cos cos table AutoQos-4.0-Trust-Cos-Table
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet1/0/1
 switchport access vlan 9
 switchport mode access
 spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
 switchport access vlan 8
interface GigabitEthernet1/0/4
 shutdown
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
 shutdown
interface GigabitEthernet1/0/10
 shutdown
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
 shutdown
interface GigabitEthernet1/0/13
 shutdown
interface GigabitEthernet1/0/14
 shutdown
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
 shutdown
interface GigabitEthernet1/0/17
 shutdown
interface GigabitEthernet1/0/18
 shutdown
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
 shutdown
interface GigabitEthernet1/0/21
 shutdown
interface GigabitEthernet1/0/22
 shutdown
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
 shutdown
interface GigabitEthernet1/0/25
 shutdown
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
 description Access Point (24)
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
 shutdown
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
 shutdown
interface GigabitEthernet1/0/43
 shutdown
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
 shutdown
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
 switchport trunk native vlan 9
 switchport mode trunk
interface GigabitEthernet1/1/2
 shutdown
interface GigabitEthernet1/1/3
 shutdown
interface GigabitEthernet1/1/4
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan8
 ip address 192.168.71.1 255.255.255.0
interface Vlan9
 ip address 207.32.40.45 255.255.255.0
ip default-gateway 207.32.40.1
no ip forward-protocol nd
no ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 207.32.41.1
ip ssh time-out 60
ip ssh version 2
end
Thanks for posting the config of the switch. This is quite helpful. In the config I see that you have configured interface vlan 9 with address 207.32.40.45 and have configured interface vlan 8 with address 192.168.71.1 and you have configured ip routing. So I would expect that devices in those two subnets should already be able to communicate with each other. Is this not the case?
The main issue that I notice in the config is the configured default route
which seems to have a typo. If you correct the next hop address then I believe that your default route should work.
Rick
Rick
version 15.2
no service pad
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip routing
vtp domain cisco
default copy
redundancy
mode sso
match cos 4
match cos 1
match cos 5
match cos 2
match dscp cs1
match cos 3
class class-default
class class-default
no ip address
shutdown
negotiation auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan8
interface Vlan9
no ip http server
ip ssh time-out 60
ip ssh version 2
end
no ip default-gateway 207.32.40.1
ip route 0.0.0.0 0.0.0.0 207.32.40.1
Try above changes and save config and test and let us know.
BB
The suggestion to remove ip default-gateway will have no effect. Correcting the typo in the third octet of the configured static default route will have an effect.
ip default-gateway is used when the switch is acting as a layer 2 device and is ignored when ip routing is enabled on the switch (as is the case here). Having ip default-gateway configured does not cause any issue when ip routing is enabled and could be useful if there is ever a situation where ip routing were not operating.
Rick
Rick
