Cisco 3662 Multiplatform router
logan-7
Here is issue, I have a 3662 router with 2 2FE-2w and a PRI 1CT-CSU. One of hte 2FE-2W has 2 1DSU-T1 v2 Wic and the other has 1 1DSU-T1 v2 wic and 1 Vwic-1MFT-T1. the 3662 has a AIM-ATM module installed in it.
My problem is the IOS sees the PRI and the ATM controller but doesn't see any of the 1DSU-T1 v2 wic( of which there are 3 of them) the IOS that I am running is. c3660-js-mz.123-15a.bin
Any reason why?.
thanks.
cdusio
Level 4
Level 4
Like said above its not supported in 3662. Its suprising that the module seem to be support on 3631, but not 3660. The link below will give you an idea of what platforms are supported.
http://www.cisco.com/warp/public/cc/pd/rt/1700/prodlit/wicds_ds.pdf
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
