Port Forewarding
mg.insight
Could anyone tell me the correct command line to add a port range 16384 to 20384 in addition to my existing ports?
Currently I use the following:
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.2.1 80 interface Dialer1 80
ip nat inside source static tcp 192.168.2.1 25 interface Dialer1 25
ip nat inside source static tcp 192.168.2.1 443 interface Dialer1 443
ip nat inside source static tcp 192.168.2.1 444 interface Dialer1 444
ip nat inside source static tcp 192.168.2.1 4125 interface Dialer1 4125
cdusio
Level 4
Level 4
I don't beleive you can do a port range on that. Checked documentation but can't find anything supporting it.
Chris
