cisco 3800 - C3845-IPBASE-M), Version 12.4(24)T2, RELEASE) int vlan not working
Abhishek Nagar
hi
I have the Cisco 3800,
C3845-IPBASE-M), Version 12.4(24)T2, RELEASE),
I am trying to create the int vlan, in global configuration command, but it does not give me the option
can you please suggest what can be the problem?
below is the print of sh ver
JSY-CENTRAL-MSC-3845#sh ver
Cisco IOS Software, 3800 Software (C3845-IPBASE-M), Version 12.4(24)T2, RELEASE)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 19-Oct-09 21:47 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
JSY-CENTRAL-MSC-3845 uptime is 2 years, 26 weeks, 1 day, 14 hours, 12 minutes
System image file is "flash:c3845-ipbase-mz.124-24.T2.bin"
Cisco 3845 (revision 1.0) with 210944K/51200K bytes of memory.
Processor board ID FCZ10417484
4 FastEthernet interfaces
4 Gigabit Ethernet interfaces
2 Serial interfaces
2 Channelized/Clear E1/PRI ports
2 Channelized (E1 or T1)/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
John Blakley
You'll need to create subinterfaces to create your vlans. Suppose you have int g0/1:
int g0/1
descript vlan 1
int g0/1.10
descript vlan 10
encapsulation dot1q 10
ip address 192.168.10.1 255.255.255.0
Then you'll trunk the port on the switch and you should be good.
HTH,
John
HTH, John *** Please rate all useful posts ***
