Cisco 3825 RAM Upgrade
We need to upgrade the RAM on our 3825 Cisco Router.
Currently, it's 512MB and we want to upgrade it to 1GB.
So do I just order another 512MB DRAM Memory?
What is the part number that I need to order?
Here is the show ver:
Cisco IOS Software, 3800 Software (C3825-ADVENTERPRISEK9-M), Version 12.4(24)T2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 19-Oct-09 21:05 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
aunsweqnix-gw-1 uptime is 3 weeks, 6 days, 8 hours, 51 minutes
System returned to ROM by reload at 23:19:46 UTC Wed Oct 10 2012
System image file is "flash:C3825-adventerprisek9-mz.124-24.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.2) with 486399K/37888K bytes of memory.
Processor board ID FHK1415F0WC
2 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
126000K bytes of ATA System CompactFlash (Read/Write)
Please advise.
Jenna
Ivan Shirshin
Cisco 3825 has to DRAM slots.  The two DIMM slots can be upgraded with 128-MB, 256-MB, or 512-MB DIMMs to a maximum of 1024 MB. If only one SDRAM DIMM is used, it can be installed in either DIMM connector.
So if you have 1*512Mb installed, you can buy additional MEM3800-512D to have 1024.
But if you have 2*256Mb, you would need to replace them with 2*MEM3800-512D.
Here is how to find location of the memry modules to check what you have currently installed and to upgrade/replace them:
http://www.cisco.com/en/US/docs/routers/access/3800/hardware/installation/guide/38comp.html#wp1008551
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Thanks Ivan!
Welcome!
Kind Regards,
Ivan
