mGre via UMTS
Kruemel2oo2
I hope somebody can help me.  I want a MultiGre tunnel via UMTS.
Here are my Configs.
mHub:
interface Tunnel1
  ip address 192.168.1.254 255.255.255.0
  no ip redirects
  ip nhrp map multicast dynamic
  ip nhrp network-id 1
  ip nhrp holdtime 600
  ip nhrp registration timeout 30
  no ip split-horizon eigrp 10
  tunnel source GigabitEthernet0/1
  tunnel mode gre multipoint
  tunnel key 12345
interface GigabitEthernet0/1
ip address  X.X.X.X S.S.S.S
  duplex auto
  speed auto
Spoke:
interface Tunnel1
  ip address 192.168.1.76 255.255.255.0
  ip nhrp map multicast X.X.X.X
  ip nhrp map 192.168.1.254 X.X.X.X
  ip nhrp nhs 192.168.1.254
  tunnel source Cellular0/1/0
  tunnel destination X.X.X.X
  tunnel key 12345
interface Cellular0/1/0
  ip address negotiated
  ip nat outside
  ip virtual-reassembly in
  encapsulation ppp
  dialer in-band
  dialer string gsm
  dialer-group 1
  async mode interactive
  ppp authentication pap callin
  ppp chap hostname xxxxx
  ppp chap password 0 xx
  ppp ipcp dns request
sh int tun 1 //Spoke
Tunnel1 is up, line protocol is up
   Hardware is Tunnel
   Internet address is 192.168.1.76/24
   MTU 17912 bytes, BW 100 Kbit/sec, DLY 50000 usec,
   Encapsulation TUNNEL, loopback not set
   Keepalive not set
   Tunnel source Y.Y. Y.Y (Cellular0/1/0), destination X.X.X.X
    Tunnel Subblocks:
       src-track:
          Tunnel76 source tracking subblock associated with Cellular0/1/0
           Set of tunnels with source Cellular0/1/0, 1 member (includes iterators), on interface <OK>
   Tunnel protocol/transport GRE/IP
     Key 0x7B, sequencing disabled
     Checksumming of packets disabled
   Tunnel TTL 255, Fast tunneling enabled
   Tunnel transport MTU 1472 bytes
   Tunnel transmit bandwidth 8000 (kbps)
   Tunnel receive bandwidth 8000 (kbps)
   Last input never, output 00:00:26, output hang never
   Queueing strategy: fifo
   Output queue: 0/0 (size/max)
      0 packets input, 0 bytes, 0 no buffer
      Received 0 broadcasts (0 IP multicasts)
      0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
      278 packets output, 33440 bytes, 0 underruns
      0 unknown protocol drops
There are output packets but no input packets.
What could be the reason?
Jörg
Kruemel2oo2
If I debug the tunnel (spoke) I get these information:
*Nov  8 12:38:29.662: Tunnel1: GRE/IP encapsulated [Cellular_IP]->[Tunnel_Destination] (linktype=74, len=120)
*Nov  8 12:38:29.662: Tunnel1 count tx, adding 0 encap bytes
Maybe it helps.
Jörg
